I'm blaming treated lumber for this. 1999 home with older CCA I assume wood deck over a garage. The AL clad over the garage door trim is a wreck but isn't it odd that the gutter bottom is so badly deteriorated since it is not in direct contact with the treated lumber?
35.67 KB
48.84 KB
What about those growies in the second photo. I see alot of damage below planters on balconies. If the planters leak behind the siding.....
Do you have an establishing shot of the side of the building?
Did they have a dog?
No. They had two cats that were locked in a bathroom which was the last room I inspected. Even though their litter box was in the tub, one of them crapped in the tub drain. Good times.
29.59?KB
42.72 KB
Water spillover from planter boxes on upper ledge? And maybe fertilizer of sorts added to planter boxes when watering?
May just be image, but some siding looks warped or just not flat on sheathing.
Maybe water behind/under siding and down to lintel?
In that case, I'd blame the human male resident.
  • 4 weeks later...
