Here's mine. I may use a more imperative tone if there are small children or if my client is expecting, but only if the place is a real POS.
All houses built prior to 1978 likely contain lead paint. As of 2010, any contractor or landlord doing work that disturbs more than 6 square feet of painted surface are required to comply with the Lead Renovation Remodeling and Repainting Rule. You should be aware that repairing and remodeling houses that contain lead paint may be more costly. Everything you ever wanted to know about lead based paint hazards can be found at http://epa.gov/lead/
