This main disconnect needs a fuse puller to shut down the system. Do any residential codes make this a no-no?
I did not see an amp rating for these fuses. Could it be on the back or is it color coded?
39.21?KB
15.11?KB
Yes, a disconnect is required as a rule, but there may be one hidden closer to the source?
Does pulling the inner door out and down maybe open the circuit? I can't see the diagram very well. But it looks like it may be a disconnect as well as a door.
10KA is a fuse rating, but not the size, and many different sizes of fuses come in green, so no help there.
The nuts and bolts are from where?
That looks like a pullblock inner door. It looks like the block was supposed to be screwed to the portion on the bottom of the photo in the first picture and someone unscrewed it. Are those the screws and nuts there - did you remove them?
I thought the door was the disconnect. I don't open these as a rule but when I lightly tugged the door just opened up. I don't know what the nuts are for. It may have been tampered with.
53.95 KB
The screws and nuts are there 'cuz someone tampered with it. The cover and pull block were one unit. When that cover/pull block is in place the two blades on the pull block engage the contacts circled in the photo below. Someone unscrewed those screws and the nuts fell inside. They're lucky they didn't short something out and cause an arc flash.
38.67?KB
