Multi-wire circuits
Robert E Lee
My son-in-law in is the process of installing a generator backup system at their home. There are (4) multi-wire circuits that he plans on moving over to the transfer panel. When he went for the permit today he was told that he will need to use "handle ties" on the breakers of these multi-wire circuits. I have never been aware of the need for "handle ties" on multi-wire circuits other than on the disposal/dishwasher outlet. They are located in WA state, in a suburb of Seattle, anyone else ever run into something like this?
Link to comment
Share on other sites
210.4 Multiwire Branch Circuits.
(A) General. Branch circuits recognized by this article
shall be permitted as multiwire circuits. A multiwire circuit
shall be permitted to be considered as multiple circuits. All
conductors of a multiwire branch circuit shall originate
from the same panelboard or similar distribution equip-
ment.
FPN: A 3-phase, 4-wire, wye-connected power system
used to supply power to nonlinear loads may necessitate
that the power system design allow for the possibility of
high harmonic currents on the neutral conductor.
(B) Disconnecting Means. Each multiwire branch circuit
shall be provided with a means that will simultaneously
disconnect all ungrounded conductors at the point where
the branch circuit originates.
© Line-to-Neutral Loads. Multiwire branch circuits
shall supply only line-to-neutral loads.
Exception No. 1: A multiwire branch circuit that supplies
only one utilization equipment.
Exception No. 2: Where all ungrounded conductors of the
multiwire branch circuit are opened simultaneously by the
branch-circuit overcurrent device.
FPN: See 300.13(B) for continuity of grounded conductor
on multiwire circuits.
(D) Grouping. The ungrounded and grounded conductors
of each multiwire branch circuit shall be grouped by wire
ties or similar means in at least one location within the
panelboard or other point of origination.
Exception: The requirement for grouping shall not apply if
the circuit enters from a cable or raceway unique to the
circuit that makes the grouping obvious.
Link to comment
Brandon, what version of the NEC is the para from? As almost all of the circuits in their existing panel are multi-wire circuits and none of the breakers have "handle ties".
Link to comment
  • 3 weeks later...
