Marc Posted September 11, 2012 Report Posted September 11, 2012 And yes, you've got to have eaves flashing beneath the panels, above the underlayment and over the gutter Marc, Don't you mean that the eave flashing should be beneath the underlayment? Whoops! You're right. Thanks. Marc
Greg Booth Posted September 11, 2012 Report Posted September 11, 2012 And yes, you've got to have eaves flashing beneath the panels, above the underlayment and over the gutter Marc, Don't you mean that the eave flashing should be beneath the underlayment? Whoops! You're right. Thanks. Marc ....there is most likely no underlayment (or decking). Those roof panels are probably attached directly to the purlins............Greg
squidbilly Posted September 12, 2012 Author Report Posted September 12, 2012 And yes, you've got to have eaves flashing beneath the panels, above the underlayment and over the gutter Marc, Don't you mean that the eave flashing should be beneath the underlayment? Whoops! You're right. Thanks. Marc ....there is most likely no underlayment (or decking). Those roof panels are probably attached directly to the purlins............Greg That is correct, the panels are attached directly to the purlins.
Marc Posted September 12, 2012 Report Posted September 12, 2012 Then you don't need it. Just get some eaves flashing in there. Marc
