normw Posted August 26, 2012 Report Posted August 26, 2012 I've bumped into this problem quite often, only on some receptacles located under sink for garburator and inside kitchen cabinet for range hood. When I plug in my receptacle testers (yes, I tried a few), it showed nothing, black, as if the receptacles were not connected at all. But when I plug in the garburator or range hood, they worked just fine. It happens so often that I no longer call it out, is anyone else out there see the same thing?
normw Posted August 26, 2012 Author Report Posted August 26, 2012 no idea what are you guys talking about
Brandon Whitmore Posted August 27, 2012 Report Posted August 27, 2012 Norm, when you plug the disposal cord back in, does it start grinding or do nothing until you turn the switch on?
inspector57 Posted August 27, 2012 Report Posted August 27, 2012 I've bumped into this problem quite often, only on some receptacles located under sink for garburator and inside kitchen cabinet for range hood. When I plug in my receptacle testers (yes, I tried a few), it showed nothing, black, as if the receptacles were not connected at all. But when I plug in the garburator or range hood, they worked just fine. It happens so often that I no longer call it out, is anyone else out there see the same thing? The power is run through the wall switch first and then to the outlet and corded appliance. Same as turning it off at the breaker. It is showed hot all the time, the appliances would run all the time. Now did you have one of those head slap moments?
