Jerry Simon Posted August 13, 2012 Report Posted August 13, 2012 I'm not an appliance guy by any means. Regardless, at a condo the other day. . . When the refrigerator door was opened and then closed, it *gurgled*. The fridge didn't wobble, but each and every time the door was opened then closed, same momentary gurgle. Didn't do it with the freezer side door. Anybody?
Les Posted August 13, 2012 Report Posted August 13, 2012 Sub-zeros have a drain in the bottom of the ref section that often will fill to capacity and "gurgle" when opening door. The freezers don't have that drain. Those drain lines are always nasty.
Marc Posted August 13, 2012 Report Posted August 13, 2012 I've had the same sound happen when I open the freezer door. Never could figure it out. Marc
kurt Posted August 13, 2012 Report Posted August 13, 2012 Sub Zero's extract air from the 'frig when the door is closed. Was it a Sub Zero?
Jerry Simon Posted August 13, 2012 Author Report Posted August 13, 2012 Sub Zero's extract air from the 'frig when the door is closed. Was it a Sub Zero? No
inspector57 Posted August 13, 2012 Report Posted August 13, 2012 Pressure change when the door is closed due to rapidly cooling air shrinking and sucking air through the drain. Might be a dirty or partially clogged drain.
