in my part of south carolina there are almost no whole house surge protectors used. I tried to talk my trane dealer into installing one on the circuit of my two new expensive hvac systems , or on the main breaker box but he would not do it.
whats up? do they not work, or are they too troublesome.
in some parts of the country the power companies seem to install them but here in coastal south carolina, south carolina electric and gas does not
I have not heard any reason not to install a surge protector, so we can assume the people you asked didn't know much about them?
We get more brown outs here than surges. I never see whole house surge protectors installed probably for that reason. It can't do any harm though, as long as it is installed safely and correctly.
They work just fine and they're a good idea if you have a lot of surges in your area.
I'm not sure about South Carolina, but in Oregon, HVAC installers generally only have limited electrical licences. They can install wiring associated with their equipment only on the load side of the breaker serving their circuit. So they're probably not the people to talk to about installing a surge protector.
Ask a real electrician to help you out.
1984 ish cutler hammer ch7 JJ for house main breaker
the a/c compressor 3 1/2 ton and strip heat boxes are pull out disconnects mounted near the outside unit of course..
also have a 2 ton upstair split system , outside condenser has a pull out disconnect too.
I could be happy with just protecting those hvac units as they are the big money
Panel be full
but it would be a good and easy fix
thanks
Then there's another version that consists of a pair of bundled 20-amp breakers. You take out two existing 20-amp breakers and replace them with a dual 20-amp surge protector.
  • 3 weeks later...
I know that Mister Sparky in Charleston offers whole house surge protection. Whole house coverage is a not just an electrical panel surge protector. You must protect every entry point. TV, Phones, and electrical. They are all connected and to not protect one could make the others useless.
