hausdok Posted February 2, 2012 Report Share Posted February 2, 2012 Hi All, Occasionally people write to TIJ directly asking for assistance with home inspection issues. This is an inquiry we'd received from an Oregon lady. Perhaps one of you Oregon-based inspectors would care to contact her via email and help her out. ONE TEAM - ONE FIGHT!!! Mike From: suzgourd@yahoo.com Hello - We live on the central Oregon coast and purchased a Heat n Glow Tiarra II about six years ago. The air intake pipe has a terminator on it, which has started to rust. The inside of the stove has also rusted, causing cracks in the burner and split/broken logs. In addition, the ignition no longer works. A service technician (who works for the business that sold us the unit) told us the unit looks much older than it is. We learned today from the business that they can find all of the necessary parts to repair the unit, except for the logs. We were told we could continue to use the broken logs and the only problem would be soot build-up. The estimated cost for the repairs is over $1,000. This does not make sense to us. Is there an inspector we could have look at the gas stove who is not partial? Any help or guidance you can provide will be truly appreciated. Thank you. Suzan Sachdeva Link to comment Share on other sites More sharing options...
Brandon Whitmore Posted February 3, 2012 Report Share Posted February 3, 2012 the only problem would be soot build-up. The estimated cost for the repairs is over $1,000. Soot build up is caused by incomplete combustion, so you'll have more CO, aldehydes, etc. I'd say that's a problem in itself. If it's really that rusty, I'd just replace it. Link to comment Share on other sites More sharing options...
Jim Katen Posted February 3, 2012 Report Share Posted February 3, 2012 I prefer not to respond by email. Is the house very close to the water? If it's within a few blocks, it sounds like you're having problems with salt air being drawn into the unit and causing corrosion. Even with repairs, this will continue as long as you draw air from the outside. Link to comment Share on other sites More sharing options...
hausdok Posted February 3, 2012 Author Report Share Posted February 3, 2012 Guys, I don't think this person is registered as a member. She sent this directly to TIJ's email. Link to comment Share on other sites More sharing options...
