kurt Posted January 31, 2012 Report Posted January 31, 2012 Does anyone have a manual or good ideas on uses of a multimeter for HI work? It'd be nice to have someone post ideas and methods for using them on the job.
Ben H Posted January 31, 2012 Report Posted January 31, 2012 I carry a Fluke 87-something. It's good for checking 240v stuff (dryer plugs, ovens & such). The temp probe is good for something I'm sure, just never use it.[:-bonc01]
Jim Katen Posted January 31, 2012 Report Posted January 31, 2012 1) Verify anything that a 3-light tester says. 2) Verify anything that a volt stick tells you. 3) Test the operation of heat pump & electric furnace elements. 4) Use it to check for current on water pipes & ground rods. 5) Use it to check the amp draw of air conditioner and heat pump compressors. Do *not* use it to check phantom voltage. For that you'll need a Wiggy.
John Kogel Posted January 31, 2012 Report Posted January 31, 2012 I have a relatively inexpensive clamp meter that I bought to measure current, (so I can be just like Jim. [] ) But I don't use it much, if ever. One restriction I have here is that I'm not permitted to "perform work" inside a breaker panel without an electrician's license. So we must be careful where we stick our meter probes, eh? One example of where I would like to take a voltage measurement in the breaker panel, but can't, is in a small multi-unit residence with underground service and no access to the meter cabinet. The only way then to determine if the service is 3-phase or single phase would be to take a measurement between the two hot conductors somewhere in the apartment. If one of the major appliances is missing, great, I can measure the voltage there. In Canada, 3-phase service means 120/208 volts for the residence. This is only significant info to some worrywart types, so I just report it as a possibility and move on in most cases.
John Kogel Posted January 31, 2012 Report Posted January 31, 2012 To use the Eico vacuum tube voltmeter (VTVM) to check a circuit, simply plug it in and wait a couple of minutes. If the tubes warm up, the circuit is good. [] Click to Enlarge 57.94 KB
Tom Raymond Posted January 31, 2012 Report Posted January 31, 2012 I carry a Fluke 87-something. It's good for checking 240v stuff (dryer plugs, ovens & such). The temp probe is good for something I'm sure, just never use it.[:-bonc01] The temp prob on mine will read up to 2000 deg F. I'm sure Ill do that often with the generous 24" lead. [:-hot]
Neal Lewis Posted January 31, 2012 Report Posted January 31, 2012 I use the multimeter to check my 18650 rechargeable flashlight batteries when they start to fail.
kurt Posted January 31, 2012 Author Report Posted January 31, 2012 To use the Eico vacuum tube voltmeter (VTVM) to check a circuit, simply plug it in and wait a couple of minutes. If the tubes warm up, the circuit is good. [] Click to Enlarge 57.94?KB That's funny. Those are all good ideas. My problem is I'm at the check battery stage, and would like to do it to test amp draw, elements, and that sort of stuff. I'm also at the age of being minimally interested in figuring it out and just want something to walk me thru it with a better manual that speaks to me more than the lame stuff currently supplied with the gear. I need a multimeter for HI work instruction manual.
hausdok Posted January 31, 2012 Report Posted January 31, 2012 Kurt, If my scanner would talk to my new computer, I'd scan some stuff for you that shows you how to use one for this gig. Alas, my computer refuses to communicate with my perfectly good 12 year old scanner that's only made about 50 scans total and I can't find a driver for the damned thing. I've been planning to go see what those things cost these days so I might have something for you in a day or so. ONE TEAM - ONE FIGHT!!! Mike
John Kogel Posted February 1, 2012 Report Posted February 1, 2012 Kurt, If my scanner would talk to my new computer, I'd scan some stuff for you that shows you how to use one for this gig. Alas, my computer refuses to communicate with my perfectly good 12 year old scanner that's only made about 50 scans total and I can't find a driver for the damned thing. I've been planning to go see what those things cost these days so I might have something for you in a day or so. ONE TEAM - ONE FIGHT!!! Mike Mike, I remember when Windows XP came out, it took me a couple of years to find a driver for my flat bed scanner. We use fax a lot to send and receive booking sheets and info, so I took a chance and bought a new multifunction machine, Samsung SCX, in 2008 and it is still performing well. In scan, copy, or fax mode, you can feed multiple sheets into it. The top hinges up so you can scan a book the old way. You can scan to a HD or to a flash drive. It was about $200. Cartridges are $75. It has its own brain, so you don't need a driver. In fact, I keep mine in the other office, and plug a laptop into it if I can't use a flash drive.
hausdok Posted February 1, 2012 Report Posted February 1, 2012 Hi, Thanks for the tip. I'll check it out. I can't afford to keep my brain in the other office; there aren't enough brain cells there already. ONE TEAM - ONE FIGHT!!! Mike
Jim Katen Posted February 1, 2012 Report Posted February 1, 2012 That's funny. Those are all good ideas. My problem is I'm at the check battery stage, and would like to do it to test amp draw, elements, and that sort of stuff. I'm also at the age of being minimally interested in figuring it out and just want something to walk me thru it with a better manual that speaks to me more than the lame stuff currently supplied with the gear. I need a multimeter for HI work instruction manual. Post a picture of your multimeter.
kurt Posted February 1, 2012 Author Report Posted February 1, 2012 I've got the basic DM-20. I'm not opposed to getting something nicer if it is beneficial to have something nicer. DM-20
Jim Katen Posted February 1, 2012 Report Posted February 1, 2012 I've got the basic DM-20. I'm not opposed to getting something nicer if it is beneficial to have something nicer. DM-20 It doesn't have a clamp, so you can't use it to measure amperage (not practically, anyway). It'll only be useful for voltage. I think you'd get more use out of a combination multi-meter, clamp-on meter. It doesn't have to be expensive. Look at the UEI D49 or the Sperry DSA 400.
ghentjr Posted February 1, 2012 Report Posted February 1, 2012 Kurt, If my scanner would talk to my new computer, I'd scan some stuff for you that shows you how to use one for this gig. Alas, my computer refuses to communicate with my perfectly good 12 year old scanner that's only made about 50 scans total and I can't find a driver for the damned thing. I've been planning to go see what those things cost these days so I might have something for you in a day or so. ONE TEAM - ONE FIGHT!!! What kind of scanner is it? Mike
David Meiland Posted February 1, 2012 Report Posted February 1, 2012 Hi, Thanks for the tip. I'll check it out. I can't afford to keep my brain in the other office; there aren't enough brain cells there already. ONE TEAM - ONE FIGHT!!! Mike If you want to fax the manual to me, I will scan and post. 360-378-8397
John Kogel Posted February 1, 2012 Report Posted February 1, 2012 I've got the basic DM-20. I'm not opposed to getting something nicer if it is beneficial to have something nicer. DM-20 It doesn't have a clamp, so you can't use it to measure amperage (not practically, anyway). It'll only be useful for voltage. I think you'd get more use out of a combination multi-meter, clamp-on meter. It doesn't have to be expensive. Look at the UEI D49 or the Sperry DSA 400. But don't waste your money on too cheap of a clamp meter. Mine only measures current down to 0.0 Amps. That is pretty useless. My 1950's vacuum tube meter is good for aligning radios. And it is fun. Here, I'm measuring the current draw of the big meter, which is only about 0.01 amps, still enough to stop your heart, but my meter reads 00.0 [] When I put a big 1500 watt load on the cord, we get a reading of 6 amps. OK the meter works. Notice how the voltage has been pulled down to 109 vac, by the heater. You want a clamp meter that reads milliamps. In the third pic, there could be current flowing thru the pipes. We still don't know for sure. Also the wires need to be separated to read amperage. You can't measure amps in a multistrand cord with a clamp meter, unless they're all carrying current from the same source. If one strand is hot and the other is neutral, the clamp reads 00.0. Click to Enlarge 55.02?KB Click to Enlarge 54.22?KB Click to Enlarge 33.21?KB
kurt Posted February 2, 2012 Author Report Posted February 2, 2012 So, tell me a meter to buy. Are the one's Jim noted OK, or should I consider something "better"? I ask, because I don't know. I never begrudge spending money for the best tool for the job.
Marc Posted February 2, 2012 Report Posted February 2, 2012 The truth is that I don't use a volt meter on the job much. I've a Fluke 336 clamp meter for checking ground rods like Jim said and to find the 208 V leg on some 3 phase unbalanced neutral residential services but that's it. I just bought an inspector III that Douglas recommended a while back. Great instrument. It's more useful to me than any voltmeter, but still too big to carry around in my pouch. I keep it and the clamp meter handy in a tool bag in the kitchen. Marc
John Kogel Posted February 2, 2012 Report Posted February 2, 2012 I looked at all the Sperry clamp meters and this model is the only one on their website that shows a picture of a display where the measurement is down to 2 decimal points. (10 mA) http://www.sperryinstruments.com/product/dsa500a $60 seems like a fair price, too. I like this one, but it uses those little button batteries that go dead pretty fast I think. http://www.valuetesters.com/Amprobe-ACD ... r-600A.php
rkenney Posted February 2, 2012 Report Posted February 2, 2012 I looked at all the Sperry clamp meters and this model is the only one on their website that shows a picture of a display where the measurement is down to 2 decimal points. (10 mA) What will you use all that resolution for (0.010 A)?
Jim Katen Posted February 2, 2012 Report Posted February 2, 2012 With the single exception of looking for minor current on water pipes, I can't imagine a situation where a home inspector would need to be able to measure milliamps. And even that exception is pushing it. If you're going to use it on the job it'll be for testing the operation of heating elements in water heaters, amp draw at compressors, operation of electric furnace/heat pump elements, and for more in-depth testing of receptacles than you can do with a three-light tester. That's all pretty crude work. You don't need anything more precise than a tenth of an amp and you don't need true RMS. Any of the baseline meters from the major manufacturers will be fine. I started using a lot of UEI equipment because they were headquartered here and I could stop in for free repairs that were done while I watched. After a while, I just got to really like them. Sperry & GB are fine. It's hard to go wrong with Fluke. Like point & shoot cameras, it doesn't really make a whole lot of difference. 1
kurt Posted February 2, 2012 Author Report Posted February 2, 2012 OK, cool thanks all. Now, I just have to figure out how to use it effectively.
John Kogel Posted February 2, 2012 Report Posted February 2, 2012 I looked at all the Sperry clamp meters and this model is the only one on their website that shows a picture of a display where the measurement is down to 2 decimal points. (10 mA) What will you use all that resolution for (0.010 A)? Looking for minor current on water pipes or grounding conductors. Why would I need a meter that reads 400, 600 or 1000 amps? I wouldn't care so much about the actual value, but I want the meter to be more sensitive than the cheap one I bought.
Chad Fabry Posted February 2, 2012 Report Posted February 2, 2012 There was a time when I used a multimeter daily, so I still have a Fluke 289, an 88 and a bunch of accessories. I recently lost my SureTest so I broke out my Fluke and it's now my daily driver on inspections. It's a little more cumbersome than the SureTest but it's paid for and I trust it without reservation. I use the inductive amp clamp and the thermometer the most, but I also use it for testing polarity, grounds and anytime the three light tester reports something funky. 1
