How do you handle hose bibs when they are turned off by their isolating valves? Do you handle the situation any different in the winter when there is potential for freezing?
Have you ever heard of an inspector being held responsible for damages caused by leaks after opening hose bib isolation valves?
If you touch them, they will leak. [:-weepn]
Yup, I have one in my house that I shut off every winter and when I turn it on in the spring it leaks into the basement and I have to tighten the locking nut. The seats get funky in the old valves and will likely not seat again when you close it, thus a drip at the hose bib. Make a note that it was off and you did not operate it.
Same here, only I call it a packing nut.
