Remoldel on older home, switched previous main panel to sub panel off new main panel. Old 200 amp main (now just a disconnect) they ran #2 AL with a 70 amp breaker in new main panel.
QUESTION: any reason the old (now subpanel) should not have been rewired with neutrals floated as they are bonded like a main panel.
old panel
34.32 KB
#2 AL from new panel
41.78 KB
70 amp breaker in new panel to sub
47.95 KB
Grounds and neutrals bonded
58.88 KB
thanks guys
The sub panel enclosure should be bonded to the equipment grounding bus bar and not the neutral bus bar. The neutrals in the sub panel should be on a bus bar that is entirely separate from the one for the EGC's.
