Robert Jones Posted September 23, 2011 Report Posted September 23, 2011 All of the "nails" were in this condition. I can't believe the siding stayed on. You think it voids the warranty? Also when you make a bad cut, just caulk the crap out of it. [:-paperba Click to Enlarge 42.36 KB Click to Enlarge 52.22 KB
Jim Baird Posted September 23, 2011 Report Posted September 23, 2011 Bubba needs to learn how to set his air nailer or give up and use a hammer.
edwardh1 Posted February 14, 2012 Report Posted February 14, 2012 Bubba needs to learn how to set his air nailer or give up and use a hammer. true. I stopped a condo residing on the first wall, when they were doing the same thing. The 'workers whose first language is not english" doing the work claimed they were unaware that there was An adjustment on the air compressor!?!?
Chad Fabry Posted February 15, 2012 Report Posted February 15, 2012 For what it's worth, one does not change the depth of drive by adjusting air pressure. Air pressure has to be sufficient to drive through sheathing or into a knot in a rafter. Depth of drive changes are made at the device. Maybe the installers knew how to set the depth of drive but had no clue what you were going about regarding the air compressor. I've shot a gazillion nails at 150 psi into a wide variety of materials ranging from old cinder block chimneys to plantation grown pine. As was necessary, I adjusted my nailers/ staplers to the specific conditions.
edwardh1 Posted February 15, 2012 Report Posted February 15, 2012 For what it's worth, one does not change the depth of drive by adjusting air pressure. Air pressure has to be sufficient to drive through sheathing or into a knot in a rafter. Depth of drive changes are made at the device. Maybe the installers knew how to set the depth of drive but had no clue what you were going about regarding the air compressor. I've shot a gazillion nails at 150 psi into a wide variety of materials ranging from old cinder block chimneys to plantation grown pine. As was necessary, I adjusted my nailers/ staplers to the specific conditions. they were driving the fastners almost all the way thru hardie planks
