Main Water Line runs under footing
Mark P
In this house, on crawl, built in 2003 the main water line from the street runs under the footing. I can't say I remember seeing this before; I typically see it running through the foundation wall – but I may be having a senior moment. Erosion is occurring under the footing from water running through this opening. Even though it has not rained here for months, there is still a puddle of water. My concern is that if the erosion continues - after a bunch of years the footing will be compromised. My questions:
Is running the water line under the footing allowed? Is it even addressed in code?
What would you say about this?
Do you share my concern about the erosion and eventually compromising the footing?
44.55 KB
64.94 KB
I would not be at all concerned about lack of support under a short section of footing like that. Could be erosion, but I suspect it's been that way since the builder left unless there's a torrent of water flowing.
I would be concerned about that much water if it "hasn't rained for months". Sounds to me like the water pipe has problems. FWIW, our neighbor's water pipe recently sprang a leak somewhere outside the foundation, with a similar amount of water inside the basement (as well as a flooded meter pit). Some flaw in the copper pipe sat there for 4 decades and finally let go.
Found two so far this year using the leak detector on the meter.
Big dollar repair.
I don't think I'd be too concerned about the lack of support over that short of distance. Instead I'd be looking for where the water was coming from.
Important Note: Utilizing the above technique with success will without fail make certain real estate agents HATE your f**king guts pretty much forever.
We almost always run the water line under the footing, and we put pipe insulation on it. One thing that happens... if you cut a ditch down a hill to the foundation of a house, you often create a channel for water to follow, if the backfilled ditch is not as compact as the soil around it. I'm watching some guys build near me right now, and they dug a 2' deep ditch down a long slope right to the middle of their building footprint. If they're smart and they compact the soil well as they backfill, they'll probably be OK. If they let the excavator flip a bunch of fluffy soil back into the ditch, and blade the rest of it out in the general vicinity, they'll have a new creek running into the crawl space.
I've got to disagree. When they do that it *always* creates an underground stream. Unless they use a jumping jack in that trench in 12" lifts it will catch & channel water into the crawlspace.
Nobody compacts trenches like that in residential construction.
not going to cite code, but supply should be sleeved and needs depth to protect from freezing. The one in the picture looks way to high up and must be leaking.
We had a house in our area where the landscaper nicked a supply line while planting a tree, and as the water heater was the first stop on the way in, the little dirt getting in piled up in the tank and ruined the heater.
Trying to figure how dirt could enter a pressurized water line.
Big dollar repair.
I pull the meter covers on all the polybutylene (big blue) era homes I inspect.
Once I found the delta spinner moving forward a few turns and then back a few turns. It kept repeating that. What was going in there?
Big dollar repair.
I've seen that, too. I'm not certain, but I THINK that if a main is, indeed, leaking, water spurts through the hole but doesn't completely dissipate due to slow absorption by clay soil or whatever.
When the pressure around the leak exceeds the line pressure, water backflows until the pocket of water around the leak is fully absorbed by the soil, sort of like Newton's "for every action there is an equal and opposite reaction".
Just a theory, however . . .
  • 5 years later...
This is my exact problem- Water is falling the pipes that run under the footing and water in springing up in the crawlspace. I read something about a sleeve, then you can add cement from the exterior, but I do not understand what kind of sleeve (DIYer). Can you help me please?
You can't just seal out the water. It's not a boat. You need to intercept the water and give it somewhere else to go.
  • Thanks 1
My split was built in 66. The front foundation has the original sleeve for the water line but it was discovered last minute that there was no where else to put the septic except where the water line was designed to go. The line was diverted to the side of my split and comes under the footing at that point. It travels under the slab of the family room and emerges in the basement. I keep "listening for leaks" but so far so good. I am not looking forward to having to replace this line in my lifetime.
