Can a return air duct for a heat pump/air handler be placed inside of a laundry closet with a Door? I can't imagine it can, but I need to ask. The temp differential would significantly drop. Is this wrong? The compressor is located on the roof and not yet connected to the electrical disconnect, so the unit was not tested for function. This is in a Condo
Is there a grille in the door? If so, it's probably okay, but not the most efficient configuration. If there isn't a grille in the door, the installer either forgot, or hasn't put it in yet.
I've seen some of those here in condos with the heat pump located in the laundry room with a tight door.
Though there was always a return grill in the laundry room wall behind the unit (hidden behind the front door)
Are you sure there isn't a grill in the wall of the laundry room somewhere?
