Charles Posted September 9, 2011 Report Posted September 9, 2011 Good morning. Posted same stuff over on the ASHI Forum but wanted to see what you guys have to say about something I discovered yesterday during a builder one year anniversary inspection. Home is a wood frame structure with a plaster finish. Approximately 3600 square feet under roof. The picture illustrates a large number of roof vents installed opposite of each other along the ridge. In my mind this would appear to defeat the purpose of the off ridge vents where they would simply draw air from the nearest vent (opposite or adjacent). Thoughts? Charles Download Attachment: Roof Vents.JPG 155.18 KB
Marc Posted September 9, 2011 Report Posted September 9, 2011 I don't see any problem with it, as long as there are soffit vents installed. What's the problem with ventilation air that flows from one roof vent to another? Ridge vents are generally open on both sides of the ridge. Marc
Nolan Kienitz Posted September 9, 2011 Report Posted September 9, 2011 I agree with Marc. Those vents don't appear to be much different than a ridge vent and as long as there are soffit vents in place with the air baffles/waffles to allow air flow from the eaves into the attic it should be just fine. Now ... if someone were to install a powered vent fan near the vents that could then cause a whole 'nother problem. Thank goodness they did not do that.
Tom Raymond Posted September 9, 2011 Report Posted September 9, 2011 It's stupid, not wrong. A more conventional ridge vent would have done the same thing and looked way better.
Jim Baird Posted September 9, 2011 Report Posted September 9, 2011 I see the same kind of ugly around here a lot.
