donstan4 Posted August 28, 2011 Report Posted August 28, 2011 can foam roofing but on with out moving air-conditions
Jim Katen Posted August 28, 2011 Report Posted August 28, 2011 can foam roofing but on with out moving air-conditions Sure. I do it all the time.
kurt Posted August 28, 2011 Report Posted August 28, 2011 Now that you mention it, I might try it that way.
Mike Lamb Posted August 29, 2011 Report Posted August 29, 2011 Only in hackensack. Hackensack? Isn't that the little bean bag thing you kick around with your feet? By the way, I've been selling images of Bain's ripped image on eBay. Sales have been brisk.
Bain Posted August 29, 2011 Report Posted August 29, 2011 Only in hackensack. Hackensack? Isn't that the little bean bag thing you kick around with your feet? By the way, I've been selling images of Bain's ripped image on eBay. Sales have been brisk. ahahahahahahahaha . . .
Tom Raymond Posted August 29, 2011 Report Posted August 29, 2011 That's only because they think it's Robert Irvine. Inspection: Impossible.
John Kogel Posted August 29, 2011 Report Posted August 29, 2011 can foam roofing but on with out moving air-conditions You shouldn't be texting while you're driving, it's dangerous. []
leeboy Posted January 16, 2012 Report Posted January 16, 2012 Foam is a great way to insulate a roof as long as you have enough of it and reach efficient R value (insulation Value) The rafters/roof framing/ trusses must be hermetically sealed in order to be effective, This method is highly recommended in a vaulted or attic type ceiling. If there is no air then there is no chance of condensation, as for the the dew point, it would exist at the center of the foam which is clearly impossible, no vapor barrier or air barrier required. It is costly.
