We're laying new engineered hardwood, and the water heater is parked in a closet, right on the subfloor, no drain pan. Here's how I rigged a lift for the tank. I fashioned a custom pan out of aluminum flashing and slipped it under. The pan has a hole punched in it corresponding with an existing hole in the subfloor. Silicone at the hole and at the corners.
For non-Boy Scouts (non-Sea Cadets), the knot on the right is a bowline, the knots on the left and around the two tank stubs are clove hitches. The friction of the rope over the 2X2 helped hold the tank up while I tied it off. [:)]
33.96 KB
24.31 KB
23.13 KB
35.19 KB
Do I get a MacGyver Badge for that, or what?
Ha, ha. Very well done.
My only concern would be lifting the tank by the inlet and outlet nipples, though I assume they survived. What's up with the 1/2" pipes? Wouldn't you get better flow with 3/4"?
The tank is empty right?
Yep. It's actually pretty light empty, but there was some resistance from the pipes. The idea was to just levitate the tank a couple of inches without doing any plumbing work.
The closet is 20" deep, and the tank is 20" in diameter. A homemade pan was the only way, and it had to be slipped in under the tank. I folded the corners, origami style.
Half inch pipe works ok. We're conservative folks up here. I won't be changing anything that isn't leaking.
