John Dirks Jr Posted July 17, 2011 Report Posted July 17, 2011 Is the method in the picture an acceptable way of securing the main breaker? If not, what is supporting documentation when calling it out? Click to Enlarge 34.07 KB
hausdok Posted July 17, 2011 Report Posted July 17, 2011 Yes, when it's designed to be secured that way. Did you look at the schematic inside the enclosure to confirm? ONE TEAM - ONE FIGHT!!! Mike
Jim Katen Posted July 17, 2011 Report Posted July 17, 2011 John Dirks Jr said: Is the method in the picture an acceptable way of securing the main breaker? If not, what is supporting documentation when calling it out? Yes, that looks like a typical Eaton hold down screw. It should work on Cutler Hammer, Challenger, &, I believe, Westinghouse equipment.
John Dirks Jr Posted July 17, 2011 Author Report Posted July 17, 2011 hausdok said: Yes, when it's designed to be secured that way. Did you look at the schematic inside the enclosure to confirm? ONE TEAM - ONE FIGHT!!! Mike No but I will next time. Thanks to both for the confirmation.
