Harpman Posted June 19, 2011 Report Posted June 19, 2011 Hello to all on the forum. I need some information on an Intertherm heater. It is model # UGC 1000-7. It is 220 volt, and needs a thermostat in the circuit. I would like some feedback on what brand or type of thermostat to get. The units are small, measuring 22" W X 14" D X 3.5" tall. The output grills and control knob is on the 3.5" face, on the 22" width section. It has the water and anti freeze unit inside with blower motor. I have no idea what the BTU's would be. I am going to install these in my motor home, a perfect size. I wonder about a few things. What would the installation clearances be, can they be installed vertically if needed, ( long side)? I intend to travel west, so these two units should be fine, and its my hope to not have to use the propane heater unless I wind up in a really cold location. Any advice greatly welcome. George E
Jim Katen Posted June 19, 2011 Report Posted June 19, 2011 Any cheapo 240-volt thermostat would work fine. I don't know what the clearances would be, but I'd guess that you'd be fine with 0" on the sides and three feet in front. I don't know about vertical installation. You'd have to find installation instructions somewhere. Good luck on that.
Terence McCann Posted June 19, 2011 Report Posted June 19, 2011 All RVs use and RV parks supply 120V. How do you plan on powering a 220V device? You can swap out the rooftop a/c for a a/c-heat pump which would work.
Harpman Posted June 19, 2011 Author Report Posted June 19, 2011 Thats news to me Terry. I was not aware of the power supply in RV parks. I guess I mistakenly assumed they provided 220 as thats what my shore power line is, and what I plug it into when at the house. Leads me to wonder why I have a 220 line in mine. My genset provides 220, but this is of course impractal when stationary at a park. I will investagate the rooftop ac/heat pump option. Thanks for your input. I suppose I will have to modify my shore line as well. Likely an adpator on the market to bring 120 in with the existing 220 plug.
Terence McCann Posted June 19, 2011 Report Posted June 19, 2011 I've owned 4 RVs and all have been 120V 30amp units. All the parks we've been to have been 120V 30amp outlets (or 120V 15amp outlets). After doing some searching on the net there are 50amp 220V units out there. My bad. Is yours a class A? Running 2 air conditioners by chance? Is there anything in your rig that uses 220V?
Harpman Posted June 20, 2011 Author Report Posted June 20, 2011 Rig is a classic 74 Travco. Orginally had two rooftop AC's, now one and a crank vent. It does have an electric hot water heater, not sure of voltage. Glad to know there's some 220 out there!
Terence McCann Posted June 20, 2011 Report Posted June 20, 2011 Harpman said: Rig is a classic 74 Travco. Orginally had two rooftop AC's, now one and a crank vent. It does have an electric hot water heater, not sure of voltage. Glad to know there's some 220 out there! The reason for the 220V is for the two rooftop a/cs. I would imagine that there are parks with 220 but I've never seen one. I always felt lucky if it were 30 amp 120. [:-party]
