Les Posted June 15, 2011 Report Posted June 15, 2011 I found a 220v double 15amp breaker in panel (15+15 = 30amp) toggles factory fastened with metal clip. top lug connected to red wire bottom lug connected to black wire single neutral and ground wire leaving panel with red and black duplex outlet under kitchen sink top of outlet connected to black wire and neutral white ground connected bottom of outlet connected to red wire and common ground, and seperate white. bottom used for plug and cord to disposer top used for plug and cord to dishwasher no photos, new construction, muni inspected, the folks are not happy when I told them I have never seen this. Anyone see this on a regular basis?
Chad Fabry Posted June 15, 2011 Report Posted June 15, 2011 The separate neutral thing is rather unnerving; are you sure it wasn't pigtailed? Other than that, I see multiwire branch circuits serving the dishwasher and disposal all the time.
hausdok Posted June 15, 2011 Report Posted June 15, 2011 Yeah, Sounds like a 15-amp MWBC to me. Like Chad says, I bet that 'separate' white is pigtailed back in the box. See disposals and dishwashers on the same MWBC all the time. ONE TEAM - ONE FIGHT!!! Mike
Les Posted June 15, 2011 Author Report Posted June 15, 2011 so the single throw will disconnect both? Wht is likely pigtailed. this is a condo sub panel, main is at meter three floors below.
John Kogel Posted June 15, 2011 Report Posted June 15, 2011 Up until recently, all Canadian counter outlets were wired that way - 15 amp split duplex*. The tab on the hot side of the receptacle is snapped off to separate the top from the bottom. On the neutral side of the receptacle, the tab is left in place, so one neutral connection supplies top and bottom. Les, since each leg supplies only one receptacle, you have two 120 volt, 15 amp supplies there. They are tied together to reduce the chance of a shock, safety issue for Sparky. The new rules (CEC 2006) allow 20 amp so that people can have unsplit GFCI outlets around the sink.
Les Posted June 15, 2011 Author Report Posted June 15, 2011 Thanks John, guess I knew that, but in this area we have not seen the breakers tied together at the panel thanks guys!
Brandon Whitmore Posted June 15, 2011 Report Posted June 15, 2011 Thanks John, guess I knew that, but in this area we have not seen the breakers tied together at the panelthanks guys! Hasn't it been an NEC requirement for years? Of course, I don't know what code MI falls under.
Jim Port Posted June 15, 2011 Report Posted June 15, 2011 A double pole 15 is not a 30 amp breaker. It is a 15 amp breaker. There should have been no reason to break the tab on the neutral side.
Les Posted June 15, 2011 Author Report Posted June 15, 2011 A double pole 15 is not a 30 amp breaker. It is a 15 amp breaker. There should have been no reason to break the tab on the neutral side. agreed!
Jim Katen Posted June 16, 2011 Report Posted June 16, 2011 Thanks John, guess I knew that, but in this area we have not seen the breakers tied together at the panel thanks guys! That's because it wasn't required until the 2008 NEC. Before that, the breakers didn't need a tie bar. Without a tie bar, it wouldn't have shown up on your radar.
