exploreparadise2 Posted June 3, 2011 Report Posted June 3, 2011 This faucet arrangement was in a 1920s building. Turn enough valves and you can have just hot water, just cold water, or warm water when they meet in the middle. It all worked fine. Click to Enlarge 28.22 KB or warm water when they meet in the middle. It all worked fine.
hspinnler Posted June 4, 2011 Report Posted June 4, 2011 Thanks for sharing. We made it all here in the USA back then.
John Kogel Posted June 4, 2011 Report Posted June 4, 2011 It's a clever arrangement, but it's also easy to see why it never caught on. You can get pure hot or pure cold by simply using one of the upper taps. [:-graduat That nickel-plated brass was bad for the economy. It never needed replacing. Much better now that we're buying Chinese fixtures, eh?[]
David Meiland Posted June 4, 2011 Report Posted June 4, 2011 Can you? Or do you have to open one of the bottom taps to get any water at all?
John Kogel Posted June 4, 2011 Report Posted June 4, 2011 David Meiland said: Can you? Or do you have to open one of the bottom taps to get any water at all? Wouldn't be so clever, then, would it?
