Mark P Posted April 20, 2011 Report Posted April 20, 2011 This is on a very old house. There were 4 other fire places and chimneys. I don't think there was every a fire place where this "chimney" is located. I've nver seen one capped like this and I want to think it was always like this, but why is my questions. Click to Enlarge 68.83 KB Click to Enlarge 70.95 KB
emalernee Posted April 20, 2011 Report Posted April 20, 2011 Where that chimney sits (centered on the ridge of that brick section of the house) tells me that there once was a fireplace below or at least a flue for a stove. I see the house in front of the brick section is made of stone. Is the stone section the oldest? Someone has had their way with the roof lines, you could almost call it rape.
mgbinspect Posted April 20, 2011 Report Posted April 20, 2011 This is on a very old house. There were 4 other fire places and chimneys. I don't think there was every a fire place where this "chimney" is located. I've nver seen one capped like this and I want to think it was always like this, but why is my questions. You're probably right, because the chimney is only about 13" x 21" leaving a flue of about 5" x 13", which is not a typical flue demension even in colonial times. Eight inches seems to be about as small as one ever sees as a depth of a working flue. And, the work seems to be pretty consistant - no obvious mismatching mortar. My guess is that it's an architectural feature - a dummy.
Inspectorjoe Posted April 20, 2011 Report Posted April 20, 2011 Did you climb a tree or utility pole to take the second picture?
Mark P Posted April 20, 2011 Author Report Posted April 20, 2011 Did you climb a tree or utility pole to take the second picture? I was still on the roof. Everything you see in the picture and more are all one rambling house.
Erby Posted April 20, 2011 Report Posted April 20, 2011 I'd bet on an old coal or wood burning kitchen range piped into the flue of that chimney. What room was below the chimney.
