I don't think so. No signs of arcing on the wire itself, or overheated components. I see corrosion only. High moisture/corrosive environment?
That's my thought too - condensation and evaporation? (Wouldn't a loose connection make for resistance and overheating - scorching, etc?)
Corrosion aided by elevated temperatures. Based on the discoloration.
Heat a plate of steel with an oxy-acytl torch and the opposite side of the plate will corrode before your eyes. Lower temperatures can do the same with enough time.
