I can't speak for the Golden State, but up here, we don't expect to see shutoffs under the sinks in a mobile home. Sometimes, people have added them, good idea. I believe in the US they are under the HUD jurisdiction.
If your unit was lacking them, it's a good bet that's the way it left the factory.
They left stuff off for two reasons, to save money and to reduce weight.
I have pics of mobile home toilets with plastic toilet tanks. Lovely.
42.46 KB
59.56 KB
Here the $90 Nikon Coolpix captures the water drops falling from the leak in the sink. Fascinating stuff. [:)]
Weren't required then. Don't know about now. Go to "library" on the menu bar above, use your cursor to make the sub-menu appear and then click on "File Downloads." Scroll down until you find The HUD Code - MHCSS (Federal Manufactured Home Construction and Safety Standards at 24 CFR 3280). Check out the section of water distribution systems.
Only requirement is main shut-off in the home or, under the home. Most manufacturers today are installing individual fixture valves and whole-house valves within the living space.
  • 2 months later...
Since you are mentioning the water heater supplies I assume the plumbing you refer to are the water pipes. We have a slew of mobile home factories in our area of Florida and back in the 70's I used to work for them installing the plumbing so I'm familiar with their construction...
[Dropped link removed by Editor. Come-on, if you're going to drop your link you could at least try and contribute to the thread.]
