rbolseth Posted February 10, 2011 Report Posted February 10, 2011 I an apollo hot water heater I use as for heat as well as a hot water heater. I've had huge problems with it not turning on. the ignitor lights and it fires up for 10 seconds then clicks off. it does this three times then stops completely. I replaced the gas valve and that didn't work. has anyone had this problem or have any answers. PLEASE HELP
Jim Katen Posted February 11, 2011 Report Posted February 11, 2011 I an apollo hot water heater I use as for heat as well as a hot water heater. I've had huge problems with it not turning on. the ignitor lights and it fires up for 10 seconds then clicks off. it does this three times then stops completely. I replaced the gas valve and that didn't work. has anyone had this problem or have any answers. PLEASE HELP Replace the thermocouple. - Jim Katen, Oregon
