John Dirks Jr Posted January 22, 2011 Report Posted January 22, 2011 Do you write up double cylinder deadbolt locks that are on doors considered for egress? Is it better to lean towards allowing occupants out as opposed to keeping crooks from getting in?
Jim Katen Posted January 22, 2011 Report Posted January 22, 2011 Do you write up double cylinder deadbolt locks that are on doors considered for egress? Yes. Is it better to lean towards allowing occupants out as opposed to keeping crooks from getting in? Of course.
mgbinspect Posted January 22, 2011 Report Posted January 22, 2011 I have for years, and clients have always been wide eyed when I have them before the door and ask what will you do in the case of a fire? I don't word it as an action item that the seller must remedy (I just see something like that as "crossing the line" - "not cricket"), but I do have it on the summary as a safety concern, so it is in the buyers face. And, when I demonstrate the gravity of the situation to them I always encourage them to take care of it immediately. There are a lot of things like dead bolts that the buyer needs to know, but I don't feel the seller is obligated to address. Similarly, Richmond used to have a lot of security bars over windows. About five months ago, a lady here actually lost her life because fo them, due to fire.
Charlie R Posted January 22, 2011 Report Posted January 22, 2011 Yep, write them up as a recommended safety related issue. Thief will just kick the door in anyway or break a window. It's a lot harder to kick the door "out" if you are inside.
Phillip Posted January 22, 2011 Report Posted January 22, 2011 I write it up no matter what the age of the house. If it in a house that was built when thumb latches was suppose to be installed I write it up as a safety concern and it goes in the summary. in older homes I write it as a safety upgrade and it just goes in the main report
Robert E Lee Posted January 22, 2011 Report Posted January 22, 2011 I agree, have pointed them out for years. I'm much more concerned with getting out of the house in case of an emergency than stopping someone from breaking in, after all it only takes a "rock" to provide an entry point at any of the windows!
Tim Maxwell Posted January 22, 2011 Report Posted January 22, 2011 A Police Officer once told me that crooks are reluctant to break glass because the sound of breaking glass is an attention getter. ?maybe? Of course nowadays it seems the crooks are pretty bold stealing AC units, copper pipes, and appliances. The last couple of stolen AC units I have seen were dismantled on site leaving the fan and cabinet and taking only the copper.
Erby Posted January 22, 2011 Report Posted January 22, 2011 Mine says: (edited as necessary) The front door operates acceptably however, the door has a deadbolt that requires a key to open from the inside. How are your children going to get out in an emergency? Generally accepted nationwide safety practices call for exit doors to NOT require a key to operate to allow for emergency exiting. I recommend the installation of a deadbolt lock that has a thumb turn on the inside portion of the lock. I also recommend that you change all locks upon moving into the home. That way you are assured that no one else has a key to your house. You should also change the code on the keypad for the garage door.
inspector57 Posted January 23, 2011 Report Posted January 23, 2011 I point it out on all exterior doors, not just the required exit doors. The confusion of a fire is all too real and deadly even if there is another acceptable door a few feet away. Do you write up double cylinder deadbolt locks that are on doors considered for egress? Which leads me to ask, is there ever an acceptable use for double cylinder deadbolts on a home? I can't think of any that would not lead to an unsafe situation.
Ben H Posted January 23, 2011 Report Posted January 23, 2011 Which leads me to ask, is there ever an acceptable use for double cylinder deadbolts on a home? I can't think of any that would not lead to an unsafe situation. Only in your grow room. [:-monkeyd
In-Depth Posted January 24, 2011 Report Posted January 24, 2011 Which leads me to ask, is there ever an acceptable use for double cylinder deadbolts on a home? I can't think of any that would not lead to an unsafe situation. Only in your grow room. [:-monkeyd Talk about a likely place for a fire! Especially with 20,000 watts of lights spliced into a single 15 amp circuit! Jim
