Hi all, forgive the dead horse since I know this has been brought up before, but what is the requirement for a single branch circuit to a detached garage? Is a disconnect means required in the detached garage? How about ground rods at the detached garage.
I can't find exact clarification in the Code Check.
Seems like I remember a single circuit (lights/outlets) is not required to have the separate ground system or disconnect but I can't remember.
Forgive my forgetfullness, it's been a long day and week.
You're remembering correctly, mostly.
The garage still has to have a disconnect but it can be a snap switch.
You don't need the grounding rod *if* the single branch circuit includes an equipment grounding conductor.
References are 225-36 and 250-32(a) in the '99 NEC. I'm sure someone here has the corresponding sections in the '02 version.
Thanks for the reply. There is an EGC.
It is fed by a 240V breaker with a shared neutral, one leg for lights, one leg for outlets. I assume that still counts as a single branch circuit?
