cbass Posted December 18, 2010 Report Posted December 18, 2010 I was at a home today with a 125,000 btu oil boiler in the basement and a fairly large coal stove in the above kitchen, both sharing the same clay lined flue. I know that you cannot share a wood burning device and a oil burning device on the same flue, but can oil and coal share a flue assuming that the flue is sized correctly? Do problems arise if both are being used at the same time? Thanks in advance.
Mark P Posted December 18, 2010 Report Posted December 18, 2010 People still cook with coal? I had no idea.
cbass Posted December 18, 2010 Author Report Posted December 18, 2010 They heat with it apparently... so... can you share the flue?
Steven Hockstein Posted December 18, 2010 Report Posted December 18, 2010 They are on different floors and sharing a flue? I would call it out just for that.
cbass Posted December 18, 2010 Author Report Posted December 18, 2010 yea, that is what i thought... the home owners explanation is that they only use one or the other...???
Jim Katen Posted December 18, 2010 Report Posted December 18, 2010 There's also this from the IRC: M1801.12 Multiple solid fuel prohibited. A solid-fuel-burning appliance or fireplace shall not connect to a chimney passageway venting another appliance.
Hearthman Posted December 27, 2010 Report Posted December 27, 2010 coal is a *solid fluel* so not allowed to be common vented with other fuels except for listed dual fuel appliances. For ex., if you have a boiler that is listed to fire coal or gas, that is allowed but not with another appliance. HTH,
