Billie23 Posted December 7, 2010 Report Posted December 7, 2010 I have an Apollo Hydroheat system, and a goodman thermostat. The air handler part of the system seems to run constatly and never get the temperature to the level I have set the thermostat at! Any suggestions?
randynavarro Posted December 7, 2010 Report Posted December 7, 2010 Could be lots of things; probably a bit too complex, at least in my mind, to troubleshoot over the internet. You'll need to call in a guy who know those systems and can troubleshoot if for you.
hausdok Posted December 8, 2010 Report Posted December 8, 2010 Clogged coils? Air filter packed with so much dirt that air can't get through? Circulator is inop? Call an HVAC tech. ONE TEAM - ONE FIGHT!!! Mike
Jim Katen Posted December 8, 2010 Report Posted December 8, 2010 I have an Apollo Hydroheat system, and a goodman thermostat. The air handler part of the system seems to run constatly and never get the temperature to the level I have set the thermostat at! Any suggestions? When was the last time you had it serviced? - Jim Katen, Oregon
