Jim Morrison Posted December 8, 2010 Report Posted December 8, 2010 For Educational Purposes, I'll offer this: Any inspector who dedicates more than a single neural synapse to whether or not the base of any toilet bowl is caulked, grouted, or otherwise chemically adhered to the floor covering is very likely missing something vital. If you ever find yourself wondering, I advise: Go back and take a look around. my two cents, Jimmy
kurt Posted December 8, 2010 Report Posted December 8, 2010 I agree. I don't think I've ever, EVER, given it a seconds thought on any job.
ericwlewis Posted January 5, 2011 Report Posted January 5, 2011 For Educational Purposes, I'll offer this: Any inspector who dedicates more than a single neural synapse to whether or not the base of any toilet bowl is caulked, grouted, or otherwise chemically adhered to the floor covering is very likely missing something vital. If you ever find yourself wondering, I advise: Go back and take a look around. my two cents, Jimmy LIKE
msteger Posted January 5, 2011 Report Posted January 5, 2011 I always say "no" to caulking the toilet/floor joint when client's ask. If there is a small leak there, you want to be able to see it. The caulking will seal in the water until the leak gets bigger and you see the damage on the ceiling under the toilet.
hausdok Posted January 5, 2011 Report Posted January 5, 2011 I always say "no" to caulking the toilet/floor joint when client's ask. If there is a small leak there, you want to be able to see it. The caulking will seal in the water until the leak gets bigger and you see the damage on the ceiling under the toilet. If I'm remembering correctly, my father's plumbing sub would always leave a gap about 1-inch wide at the very back of the pedestal, the theory being that if any water were squirting out of the seal some might drain out of the slot and provide a tip-off that something isn't right. Back then, he'd bed the pedestal in plumber's putty because they didn't have silicone caulk that's as hardy and durable as what's available today. I think that a decent bead, once fully cured, provides a more solid base if it's applied first and the pedestal is bedded into that along with the seal. I don't know that just applying a bead around the perimeter, once the pedestal is down, is doing anything except providing a neat cosmetic transition. ONE TEAM - ONE FIGHT!!! Mike
hspinnler Posted January 6, 2011 Report Posted January 6, 2011 I have inserted the moisture meter pins into the caulk to take moisture readings before. Anyone else do that?
Les Posted January 6, 2011 Report Posted January 6, 2011 In the Mid-Michigan area we see approx 1 caulked stool per 100. Never seen it cited by AHJ.
nookandcranny Posted January 8, 2011 Report Posted January 8, 2011 I think most home inspectors could easily be diagnosed with OCD. Who else goes around LOOKing for problems in someone else's house, turning on EVERY faucet, opening EVERY window... Yeah, we're pretty much nuthouse material.
plummen Posted January 8, 2011 Report Posted January 8, 2011 To prevent urine from seeping under the toilet. This is particularly important in households that include little boys. - Jim Katen, Oregon Well, after posting regarding my personal experience with why it's helpful to caulk a toilet to the floor, I now see Jim has already posted that same reason here. Yup, little boys can make keeping a busy half bath odor free tough.if youre relying on a bead of caulk to keep toilet from moving you have bigger issues! []
plummen Posted January 8, 2011 Report Posted January 8, 2011 For Educational Purposes, I'll offer this: Any inspector who dedicates more than a single neural synapse to whether or not the base of any toilet bowl is caulked, grouted, or otherwise chemically adhered to the floor covering is very likely missing something vital. If you ever find yourself wondering, I advise: Go back and take a look around. my two cents, Jimmy i find myself agreeing,that never happens! [:-slaphap
