Richard Moore Posted December 3, 2010 Report Posted December 3, 2010 Today's tiled-in jetted tub had one of those almost inaccessible access holes inside the vanity cabinet, only found after removing drawers. It was at the drain/faucet end of the tub but the motor and associated wiring was out of sight (doubtful there was GFCI in this case). My question is...what do you consider the main purpose of the access to be? Does it need to provide direct access to the motor or is it to disconnect the drain and supply plumbing, so that the whole thing can be lifted out for service, etc? I don't envy the plumber who is going to have to investigate the small, active wet patch I discovered at the ceiling directly below. I hope he is a skinny contortionist.
Jim Katen Posted December 3, 2010 Report Posted December 3, 2010 Today's tiled-in jetted tub had one of those almost inaccessible access holes inside the vanity cabinet, only found after removing drawers. It was at the drain/faucet end of the tub but the motor and associated wiring was out of sight (doubtful there was GFCI in this case). My question is...what do you consider the main purpose of the access to be? Does it need to provide direct access to the motor or is it to disconnect the drain and supply plumbing, so that the whole thing can be lifted out for service, etc? I don't envy the plumber who is going to have to investigate the small, active wet patch I discovered at the ceiling directly below. I hope he is a skinny contortionist. From the Washington State Plumbing Code: 414.1 A removable panel shall be provided to access and remove the pump.
Bill Kibbel Posted December 3, 2010 Report Posted December 3, 2010 The IRC requires access to the "electrical equipment" of a hydromassage bathtub.
Richard Moore Posted December 3, 2010 Author Report Posted December 3, 2010 Thanks guys. It didn't seem right but then I started thinking too much about removing the thing to find the leak. It's a 1968 home but the tub looks to be a lot newer. Doesn't really matter. I'm going to tell them it needs another access (and GFCI).
