Mark P Posted November 23, 2010 Report Posted November 23, 2010 What is the proper name for the lug that is circled and what is its purpose? Maybe the answer to the first question will answer the second. I'm writng up that the neutrals should not be connected there. Click to Enlarge 57.88 KB
Chad Fabry Posted November 23, 2010 Report Posted November 23, 2010 You should write up that the panel needs to be replaced; it's a corroded mess. The branch circuit wiring should not be inside the cage. OK, OK, I don't know the answers to your questions.
kurt Posted November 23, 2010 Report Posted November 23, 2010 I call it the grounding electrode lug, or grounding lug. The union guys (mostly) call it that, so I do. It's not that bad; if I wrote up every older panel that looked like that, I'd be condemning 99% of all panels.
hausdok Posted November 23, 2010 Report Posted November 23, 2010 I'd go with "grounding" lug, since the larger one next to it is the "grounded" lug. Pretty sure that's where the service grounding conductor is supposed to be; not those equipment grounding conductors (grounds) or the grounded (neutral) conductors. If I've gotten it wrong, Jim K. or Douglas will be along shortly to set me straight. ONE TEAM - ONE FIGHT!!! Mike
Les Posted November 23, 2010 Report Posted November 23, 2010 I have heard it called the shoulder lug.
Chad Fabry Posted November 23, 2010 Report Posted November 23, 2010 It's not that bad; if I wrote up every older panel that looked like that, I'd be condemning 99% of all panels. I disagree. I think it's just on the good luck side of being hot.
Jim Port Posted November 23, 2010 Report Posted November 23, 2010 In service equipment it could be used for either a grounding or grounded conductor. A grounded conductor that was too large for the neutral buss could be installed there. That lug is only listed for use with one conductor.
