Rob Amaral Posted January 12, 2004 Report Posted January 12, 2004 Folks: Anybody know of manufacturing problems with leaky 'mechanical tees' in 'wet' (glycol-filled) fire sprinkler systems? Name "National" was found on collar portion of the tee, FM-approved logo also found there. Any ideas? I'm getting stumped on "national" as far as Googling. Help would be appreciated.
Erby Posted January 13, 2004 Report Posted January 13, 2004 This one helps me when I'm not sure where else to go: http://www.thomasregister.com/ Let's you search by product or service, company name, and/or brand name. Here's a list of manufacturers with National in their name. Not sure which one it would be but would first guess the Natinal Piping Products one. Full list and links available at: http://www.plumbingnet.com/listn.html National Bathing Products 5 Greenwood Ave Romeoville, IL 60446 815-886-5900; fax: 815-886-5936 www.nationalbath.com National Control Systems, Inc. 114479 S. Pine Dr., Ste. 21 Parker, CO 80134 800-998-6493; fax: 303-840-2287 National Draeger, Inc. ... see Draeger Safety, Inc. Nationaline brand Water Heaters see State Industries National Mfg & Supply South 14th Ave Mendota, IL 61342 800-880-0442; 815-539-9786 National Network-Master Distributors 4819 Reading Rd. Dallas, TX 75247-6716 214-951-8677; 800-355-8677; fax: 214-630-1255 National Piping Products, Inc. 5906 Armour Dr. Houston, TX 77020 713-675-8529; 800-648-5721; fax: 713-675-9809 National Test Plugs, Inc. P.O. Box 3050 Palos Verdes, CA 90274 800-333-2212; fax: 310-377-5365
Rob Amaral Posted January 13, 2004 Author Report Posted January 13, 2004 Erby: Thanks. I should have thought of the Thomas Register. I'll check it out. I spoke with a local sprinkler guy and he came up with some comments to the effect that ANY glycol-filled system, no matter how good or well-installed the fittings, eventually leaks. Anybody heard of that one? I'm thinking of anti-freeze in a car....Hmmmmmm. He also said that a bunch of cheap mechanical tees ended up in the US from the Middle East somehow... R
