Scottpat Posted October 8, 2010 Report Posted October 8, 2010 At today's Flipper inspection I found the most unusual drain for a washing machine in the basement of this home. It is about 55" off the floor and goes to a small trap that is the last connection on the main line. The following photos are for your enjoyment! Click to Enlarge 49.24 KB Click to Enlarge 49.6 KB
John Kogel Posted October 8, 2010 Report Posted October 8, 2010 Signs are needed for the toilets "Do not flush during the rinse cycle". []
Plumber26 Posted November 8, 2010 Report Posted November 8, 2010 Do not like when washers use an overhead drain. Not only is it a mess when sewer line backs up, it's gotta be hard putting more head pressure on the washer's pump. But that aside, at least put a check valve in the drain line.
plumbit Posted December 17, 2010 Report Posted December 17, 2010 Hello, I am new here, if I may I have a question. In the first pic to the right of the washer drain is that Sani tee in the horizontal line legal? Thank You Todd
