AHI in AR Posted September 1, 2010 Report Share Posted September 1, 2010 Who says you can't use a trash can lid for a drain pan? So what if it doesn't even have an actual drain... Click to Enlarge 81.51 KB Link to comment Share on other sites More sharing options...
Nolan Kienitz Posted September 1, 2010 Report Share Posted September 1, 2010 They just forgot to take the manual out of the sleeve and read the installation instructions. [?] Link to comment Share on other sites More sharing options...
John Kogel Posted September 2, 2010 Report Share Posted September 2, 2010 I like it! I've been contemplating an easy pan to slip under my tank without desoldering the danged thing. A threaded nipple and a bit of goop will make a drain. [] Link to comment Share on other sites More sharing options...
Tom Raymond Posted September 2, 2010 Report Share Posted September 2, 2010 Video that for us John. I'm sure I'm not the only one that wants to see you lift a full water heater. 40 gallons of water is nearly 350 pounds. Link to comment Share on other sites More sharing options...
Les Posted September 2, 2010 Report Share Posted September 2, 2010 search the archives for water heater pan, Brian Goodman. classic stuff. Link to comment Share on other sites More sharing options...
John Kogel Posted September 2, 2010 Report Share Posted September 2, 2010 Video that for us John. I'm sure I'm not the only one that wants to see you lift a full water heater. 40 gallons of water is nearly 350 pounds. It has a shutoff and a drain tap, eh? [] Link to comment Share on other sites More sharing options...
