John Dirks Jr Posted August 29, 2010 Report Share Posted August 29, 2010 What do you think of the Tapcon large diameter anchors? Good enough to bolt a 400lb 5' tall safe to a concrete floor? Click to Enlarge 11.43 KB Click to Enlarge 22.25 KB Link to comment Share on other sites More sharing options...
mgbinspect Posted August 29, 2010 Report Share Posted August 29, 2010 What do you think of the Tapcon large diameter anchors? Good enough to bolt a 400lb 5' tall safe to a concrete floor? Click to Enlarge 11.43 KB Click to Enlarge 22.25 KB I wouldn't have a problem with the bolt itself, since the critical consideration is usually shear, which should be huge on a bolt like that. But, if you really mean to bolt into the edge of a concrete floor, I wouldn't feel to comfortable with that, fearing that the floor may actually split apart. I haven't seen the bolt before, but I like it. Link to comment Share on other sites More sharing options...
John Dirks Jr Posted August 29, 2010 Author Report Share Posted August 29, 2010 It wont be located anywhere near an edge. 48 year old basement slab without a single flaw. I doubt the concrete will break up. I was mainly wondering about the threads ability to grab the edges of the hole so they wont pull out. I suppose if you wanted to pull them out, you'de have to pull striaght up. That wont be easy with a 400lb box. Link to comment Share on other sites More sharing options...
John Dirks Jr Posted August 29, 2010 Author Report Share Posted August 29, 2010 I recently used the Tapcon screws to hang shef brackets on block and in mortar joints. They went in easy and are holding well. http://www.concretescrews.com/ Link to comment Share on other sites More sharing options...
Marc Posted August 29, 2010 Report Share Posted August 29, 2010 Eliminate the guesswork by downloading the Simpson Strong-Tie 'Anchoring and Fastening Systems' catalog. It tells you exactly how and where to install it and well as the tensile strength each bolt model offers. Marc Link to comment Share on other sites More sharing options...
Ben H Posted August 29, 2010 Report Share Posted August 29, 2010 I used these on my gun safe. I have no fear of them failing. http://www.itwredhead.com/trubolt.asp Link to comment Share on other sites More sharing options...
gtblum Posted August 29, 2010 Report Share Posted August 29, 2010 I recently used the Tapcon screws to hang shef brackets on block and in mortar joints. They went in easy and are holding well. http://www.concretescrews.com/ You really should only be using those in the block itself. They don't hold as well in mortar joints. I've never seen the big ones either, but I don't think I'd hesitate to use them on that safe. That is, if you can get them to go into the hole without breaking your wrist with the drill. If somebody wants it bad enough, Your not going to stop them from taking it, no matter what it's bolted with. Edit. You have a 400# safe and you need to bolt it down Why? Link to comment Share on other sites More sharing options...
John Dirks Jr Posted August 29, 2010 Author Report Share Posted August 29, 2010 I recently used the Tapcon screws to hang shef brackets on block and in mortar joints. They went in easy and are holding well. http://www.concretescrews.com/ You really should only be using those in the block itself. They don't hold as well in mortar joints. I've never seen the big ones either, but I don't think I'd hesitate to use them on that safe. That is, if you can get them to go into the hole without breaking your wrist with the drill. If somebody wants it bad enough, Your not going to stop them from taking it, no matter what it's bolted with. Edit. You have a 400# safe and you need to bolt it down Why? If a safe can be pushed over onto its back it becomes easier to get leverage on a big pry bar. In it's upright position, attempts to pry the door will not be nearly as easy. The store didn't have the Tapcons in the size I wanted so I went with Red Head anchor studs. BTW, I never said this was "my" safe. Anyway, the job is done. Link to comment Share on other sites More sharing options...
David Meiland Posted August 29, 2010 Report Share Posted August 29, 2010 If you need to install near the edge of a slab I would probably drill holes and use epoxy to install short lengths of all-thread. You can probably set the safe in place first, then work thru the holes in the feet. Link to comment Share on other sites More sharing options...
