palmettoinspect Posted August 24, 2010 Report Posted August 24, 2010 I’ve got a question. Was house wrap or a moisture barrier required behind vinyl siding on a house built in 1998? I understand the importance for a moisture barrier behind vinyl siding because of the number of joints and that vinyl siding is not a moisture proof exterior siding. I’ve read the current installation standard from the Vinyl Siding Institute as well as many post on the TJI. The only information I could come up with omitting a moisture barrier is from this article. http://inspectapedia.com/BestPractices/ ... g_Wrap.htm I don’t believe this house falls under any of these categories. I will definitely include in the report the importance of a moisture barrier behind vinyl siding but don’t want to raise any red flags that don’t need to be raised if this was a common practice in 1998. I only found wet OSB wall sheathing around the chimney where there was some loose trim and siding. One of the garage windows was not trimmed and I could see some black plastic around the window. Other than that there were no signs of moisture intrusion or a moisture barrier. Any help is appreciated.
Scottpat Posted August 24, 2010 Report Posted August 24, 2010 Iââ¬â¢ve got a question. Was house wrap or a moisture barrier required behind vinyl siding on a house built in 1998? I understand the importance for a moisture barrier behind vinyl siding because of the number of joints and that vinyl siding is not a moisture proof exterior siding. Iââ¬â¢ve read the current installation standard from the Vinyl Siding Institute as well as many post on the TJI. The only information I could come up with omitting a moisture barrier is from this article. http://inspectapedia.com/BestPractices/ ... g_Wrap.htm I donââ¬â¢t believe this house falls under any of these categories. I will definitely include in the report the importance of a moisture barrier behind vinyl siding but donââ¬â¢t want to raise any red flags that donââ¬â¢t need to be raised if this was a common practice in 1998. I only found wet OSB wall sheathing around the chimney where there was some loose trim and siding. One of the garage windows was not trimmed and I could see some black plastic around the window. Other than that there were no signs of moisture intrusion or a moisture barrier. Any help is appreciated. I don't think a moisture barrier or house wrap was required until 2006 in the IRC. I can't look it up right now, but for some reason 2006 is standing out as the year.
palmettoinspect Posted August 24, 2010 Author Report Posted August 24, 2010 Iââ¬â¢ve got a question. Was house wrap or a moisture barrier required behind vinyl siding on a house built in 1998? I understand the importance for a moisture barrier behind vinyl siding because of the number of joints and that vinyl siding is not a moisture proof exterior siding. Iââ¬â¢ve read the current installation standard from the Vinyl Siding Institute as well as many post on the TJI. The only information I could come up with omitting a moisture barrier is from this article. http://inspectapedia.com/BestPractices/ ... g_Wrap.htm I donââ¬â¢t believe this house falls under any of these categories. I will definitely include in the report the importance of a moisture barrier behind vinyl siding but donââ¬â¢t want to raise any red flags that donââ¬â¢t need to be raised if this was a common practice in 1998. I only found wet OSB wall sheathing around the chimney where there was some loose trim and siding. One of the garage windows was not trimmed and I could see some black plastic around the window. Other than that there were no signs of moisture intrusion or a moisture barrier. Any help is appreciated. I don't think a moisture barrier or house wrap was required until 2006 in the IRC. I can't look it up right now, but for some reason 2006 is standing out as the year. Thanks Scott. Looking forward to hear what you have to say.
Bain Posted August 24, 2010 Report Posted August 24, 2010 There's a local company here--that's in the top 50 nationwide in the units-sold column--that hasn't used a WRB behind vinyl in over a decade. They still don't, as far as I know. This is ass-backward Kentucky, but this company, for the most part, plays by the rules.
Bill Kibbel Posted August 24, 2010 Report Posted August 24, 2010 Scott is correct. WRB was not a requirement in the IRC until the 2006 edition.
Tom Raymond Posted August 25, 2010 Report Posted August 25, 2010 Could you clarify that? Was there no WRB requirement before 2006, or just for vinyl?
Scottpat Posted August 26, 2010 Report Posted August 26, 2010 Could you clarify that? Was there no WRB requirement before 2006, or just for vinyl? Just for vinyl.
Jim Katen Posted August 26, 2010 Report Posted August 26, 2010 Could you clarify that? Was there no WRB requirement before 2006, or just for vinyl? Vinyl, aluminum, steel, particleboard, plywood, & wood siding. None of them required sheathing paper before the '06 IRC. - Jim Katen, Oregon
palmettoinspect Posted August 26, 2010 Author Report Posted August 26, 2010 Thanks guys. Always alot of help.
Scottpat Posted August 26, 2010 Report Posted August 26, 2010 Could you clarify that? Was there no WRB requirement before 2006, or just for vinyl? Vinyl, aluminum, steel, particleboard, plywood, & wood siding. None of them required sheathing paper before the '06 IRC. - Jim Katen, Oregon Thank you, I never looked the others up and I just assumed it was required.... I think vinyl siding is the only one I have ever seen without it.
Tom Raymond Posted August 26, 2010 Report Posted August 26, 2010 Same here Scott, well mostly. My house has no building paper under the original wood claps. The first addition doesn't have any paper either, but the second addition has red rosin paper on it and near as I can figure it was built in the late 1890's. I see lots of vinyl installed right over the sheathing, and every time I take one apart there is water damage.
