Bain Posted August 2, 2010 Report Posted August 2, 2010 . . . but when I looked at this new condo building, I had to wonder why no one ever said, "Wait, maybe that isn't wise." Click to Enlarge 43.18 KB
Jim Katen Posted August 2, 2010 Report Posted August 2, 2010 Don't they know the receptacles are supposed to go *over* the spigots?
mgbinspect Posted August 2, 2010 Report Posted August 2, 2010 However, they do have the latest state of the art weathershields. [:-thumbu]
Terence McCann Posted August 2, 2010 Report Posted August 2, 2010 However, they do have the latest state of the art weathershields. [:-thumbu] Weatherproof enclosure testing facility?
Tom Raymond Posted August 2, 2010 Report Posted August 2, 2010 Go back and look again, they're not even GFCI receptacles. Then again I'm not suprised. Thanks John, I almost spit my coffee out my nose.
Marc Posted August 2, 2010 Report Posted August 2, 2010 Go back and look again, they're not even GFCI receptacles. Then again I'm not suprised. That doesn't mean that they are not GFCI protected, of course, I'm just refreshing your memory. Marc
Tom Raymond Posted August 2, 2010 Report Posted August 2, 2010 Go back and look again, they're not even GFCI receptacles. Then again I'm not suprised. That doesn't mean that they are not GFCI protected, of course, I'm just refreshing your memory. Marc Yes, but I'm a big fan of putting controls where people actually might be when they need to use them. That means installing GFCI receptacles where they are needed, not GFCI breakers or protecting all the outside power with the GFCI behind the freezer in the garage. Besides, the last time I shopped for GFCI's a breaker was 5 times the cost of a receptacle.
hausdok Posted August 2, 2010 Report Posted August 2, 2010 Yes, but I'm a big fan of putting controls where people actually might be when they need to use them. That means installing GFCI receptacles where they are needed, not GFCI breakers or protecting all the outside power with the GFCI behind the freezer in the garage. Does that mean that if you inspect a home with four exterior receptacles - one on each side with the GFCI protecting them all next to the back entrance - that you write them up because there aren't GFCI receptacles at each? ONE TEAM - ONE FIGHT!!! Mike
Tom Raymond Posted August 2, 2010 Report Posted August 2, 2010 No, but I would mention that it's damned inconvenient to run to the back of the house when the Xmas lights you plug in out front trip the GFCI. Case in point, I once spent the better part of an hour trying to locate the GFCI on a house set up much like your example only to find it burried behind the pedestal sink in the closet sized powder room that no one ever used. I think when we as inspectors discover design flaws that will make using a home inconvenient we should mention them.
GrantJones Posted August 2, 2010 Report Posted August 2, 2010 Clients do appreciate it when I tell them the same. But it's always verbal if they're standing there while I just spent 10 minutes figuring out the master bath controls all the bathrooms or something... Never goes in the report. BTW, this is an awesome pic. Genius!
Tim Maxwell Posted August 3, 2010 Report Posted August 3, 2010 Clients do appreciate it when I tell them the same. But it's always verbal if they're standing there while I just spent 10 minutes figuring out the master bath controls all the bathrooms or something... Never goes in the report. I started many years ago adding it to my report where the resets are. Once you set it up as part of your boilerplate/formset it's just a couple of clicks here and there.
