CheckItOut Posted July 22, 2010 Report Posted July 22, 2010 Just checking to see if there is some funky fine print clause somewhere the just pertains to fuse panels that might allow this. House built in the 20's and you can see a 10 AWG wire attached to the lugs at the top. Wires then exit the box and go into a box with one breaker - no label and I could not open that little box and have no idea the rating of the breaker - box was painted closed and breaker handle painted in place - nice. Click to Enlarge 57.66 KB
John Kogel Posted July 22, 2010 Report Posted July 22, 2010 I would just call for replacement of the whole shebang. It probably never was right, but the main thing is that we have better and safer ways to provide power to the house now, so install a new breaker panel and avoid a catastrophe.
Jim Katen Posted July 22, 2010 Report Posted July 22, 2010 Never allowed. But since you asked about fine print, in some commercial buildings, you might have been able to get away with this for supplying power to the certain critical systems such as exit signs or emergency lighting. Nowadays, we have reliable battery power sources for those systems and we don't have to squeak around the code anymore. - Jim Katen, Oregon
CheckItOut Posted July 22, 2010 Author Report Posted July 22, 2010 Never allowed. But since you asked about fine print, in some commercial buildings, you might have been able to get away with this for supplying power to the certain critical systems such as exit signs or emergency lighting. Nowadays, we have reliable battery power sources for those systems and we don't have to squeak around the code anymore. - Jim Katen, Oregon That is interesting. Thanks for your comment.
GrantJones Posted July 22, 2010 Report Posted July 22, 2010 Doesn't this break the 6-Hand Movement rule for emergency cutoff? I understand the number was greater in the past, but I was taught that there should be no tapping of the main wire before the main cutoff for the home. That makes it an unsafe situation, right? That's how I'd have written it up. Just replacing the whole box is an excellent recommendation for sure!
