I am hoping someone can shed some light on aluminum roofing for me. This particular one seems to be coated with granules, so a little new to me. Resembles a composition shingle except it is metal below.
126.7 KB
90.07 KB
Hi,
Yeah, steel I think. I see 'em every once in a while. Found out the hard way that I'm a little bit too, uh, er, chubby to walk on 'em.
  • 3 weeks later...
Hi,
Aluminium roofs look great on nearly every style of home. This appearance is further enhances by the fact that aluminum roof panels come in many different styles including cedar, slate, and standing seam. Aluminum roof shingles can also be found in numerous colors. Most metal types of roofing are light weight, durable, and then tend to have a lifespan of up to fifty years. Aluminum roofs are environmentally friendly too, which means that they'll fit in with your current lifestyle.
The drawbacks include the fact that metal roofing is hard to install, it can be expensive, and it might need a few paint touch-ups now and again.
Hey Robert, and anyone else. Bring your magnetic up with you when you check the roof, no question if it's steel. [:-graduat
Steel is a bit heavier and will rust if the surface is damaged, so you want to ID it if you can. Otherwise, when you're not sure, it is "metal", anyway.
  • 4 weeks later...
Hi,
Aluminum roof shingles can be the perfect choice for your home, real estate or even your heritage property. This type of shingle weighs lighter than steel, rustproof and stronger compared to asphalt or any other laminated shingles. In addition, aluminum shingles are tough and offer lifetime durability and superior performance upon installation. 1. High-durability: Aluminum shingles are highly durable. This is because aluminum is rustproof and strong. 2.Longer Life: aluminum shingles are considered to be a life-time roofing solution with a rating of 10 or more. 3. Aesthetics: Aluminum shingles are manufactured and designed to resemble the appearance of asphalt, tiles, cedar shakes or other specific and unique heritage roofing designs out there. With this, it can bring elegance, ruggedness and style combined with superior performance to your home or just about any real estate property. 4. Recyclable Roof: Since aluminum shingles are made with recycled aluminum, it can be recycled all over again rating it a top environmental choice of all the shingle types. 5. Cost - effective: Aluminum shingles may be considered as the most expensive shingle on the market today.
