member deleted
Locked
    121
Everything posted by member deleted
  1. How would ever know which one your are inspecting is the "one in a couple of thousand?" Unless you are a licensed Plumber, I would write up every one. Let the Plumber make the determination on whether or not the Trap needs to be replaced or reconfigured. Kevin
  2. never mind...answered my own question
  3. That is the requirement for new construction. I wouldn't write it up as a repair issue. However, I usually make a comment on verification of permits and suggest one be installed. Remember, your inspection is not code compliant. Although installing a new hot water heater requires a building permit, not many home owners, or contractors for that matter obtain one. Again, I usually make a comment about checking and verifying that building permits were obtained and that the water heater installation does not meet current and established building practices. Yes, they are required. Plywood is acceptable. Kevin
  4. I always write them up regardless of the age of the property. It doesn't really matter to me if the S-Trap is original or some knucklehead re-configured the trap to be a S-Trap. It still is a potential heath concern with the possibility of sewer gases entering the residence. So, I call for a Plumber to repair them.
  5. I use a Protimeter http://www.inspectortools.com/neaqbypr.html Works very well Kevin
  6. I would also like to see a report posted that was written by either Les, Jim, or Mike. Or, all three. Show us how it supposed to be done! Kevin
  7. The advise given so far is sound. However, my suggestion is to hire a professional inspector to evaluate the property. Kevin
  8. Kyle, Relax! Put this particular situation aside and read what you have written. Why would you be frightened to hear an HI use the term "alarmist?" There are many HI's out there that over state issues and call for "further evaluation" on a lot of things that are minor or just about everything they write up. That is a sad fact!! There is a difference between a RE using the term to describe an inspector who is thorough and someone (RE or inspector) using the term to describe someone who has over exaggerated an issue. I don't pander to RE's either, and I resent your insinuation that I do. Kevin
  9. It's also a requirement for UF cable. "340.12 (10) Type UF cable shall not be used as follows . . . Where subject to physical damage." The requirement for physical protection has moved around in the code over the years, but it's been a continuous requirement since at least the 1947 edition (my oldest one). "3003.b Mechanical Injury. If subject to mechanical injury, conductors shall be adequately protected." True. Clearly, the code intends that, in certain circumstances, it's ok to run UV-resistant UF cable, unprotected, on the outside of a building. But there are limitations on how it can be done and where it can be done. They can't be installed where they're subject to physical damage. The cables in your pictures -- as far as I could see -- looked pretty well protected. They were behind the AC cabinets and it looked like it'd be pretty hard for someone to accidentally whack them. (I'll ignore, for now, the inadequate work space in front of the disconnect boxes.) On the other hand, the picture that John posted showed the UF cable sitting out there with its metaphorical butt on the bumper. Any weed whacker could physically damage it. Given the wording of the code, I think it's reasonable for those guys to allow exposed cables in some circumstances. That doesn't mean that it should be allowed in every circumstance. - Jim Katen, Oregon After John posted his third image of this circumstance, I can see why he would have a concern about the protection of the cable. However, his original question was whether or not the cable clamped to the wall needed to be in conduit. The answer is "NO" Kevin
  10. OK....a few more comments. The two people in the thread who have quoted code both have stated that it is "subjective" and "open to interpretation." I'm no code thumper, but the general rules for UF cable are exposed cables should closely follow bldg surface. The "protect exposed cable from physical damage" is a requirement for NM cable (dry locations). Underground feeder cable (UF) that is emerging from the ground is required to be protected from 18 in below grade to 8 ft above grade. However, the cable running from the disconnect to the condensing unit is not buried cable. If you inspect in an area where builders and the AHJ treat this cable the same a buried cable and require it to be in conduit, then great. That is not the case in my area. Therefore, I stand behind my comments and say that this is acceptable and that all of the national builder, all of the AHJ's for each jurisdiction in MD, DC, and VA, and all other electricians or HVAC specialists are NOT wrong. But, what the hell do I know.....I'm just an inspector. Kevin ps...Mike, I don't think you are a wind bag. It's just envy I always have a lot to say, but can't type worth a crap! I guess people might call me long winded if I made the effort to learn how to type with more than two fingers.
  11. Chris, I believe you are talking in general terms, but I agree! When it comes to electrical issues that need "correction", I write them up and recommend a licensed electrician fix whatever it is that needs to be fixed. What I was referring to in my previous post to John is that I didn't see an issue with the cable (lack of conduit). It didn't need correction. However, if the cable run from the disconnect to the condensing unit was long, and he felt that there could be a concern for possible accidental damage, I would make a recommendation to "improve" the cable by providing additional protection. That recommendation would be classified as a maintenance item, which I define as the following: MAINTENANCE ISSUE (MI): The item, component, or system while perhaps functioning as intended is in need of minor service or maintenance; is showing signs of wear or deterioration that could result in an adverse condition at some point in the future; or considerations should be made in upgrading the item, component, or system to enhance the function, efficiency, safety, and/or more closely align with current construction standards. Items falling into this category can frequently be addressed by a homeowner or handyman and are considered to be routine homeowner maintenance or recommended upgrades. However, it is recommended that all work be completed by qualified individuals or companies. If you are inspecting a home built prior to 2000, would you write up the lack of AFCI protection as a "repair" item or a recommended safety upgrade? Kevin
  12. You didn't directly answer my question from the previous post. You have made a long winded argument on "drip edge" flashing, which is a recommendation from Roofing Associations. While I agree with you on that issue, it doesn't relate to the conduit issue. What we are talking about is weather conduit is required by code in my area (MD, DC, VA). So, I will ask the question again. Are you saying that every builder, every AHJ in my area, every electrician, and every HVAC tech who has installed cable that is not in conduit from the disconnect to the condensing unit is wrong? Kevin
  13. Reading that, I'd say that cable should be protected in conduit on the wall where it's exposed. If I'd done the inspection, I would have written it up that way and quoted Hansen, since he's the best independent authority on the subject that I know of, and I would have recommended that they have it corrected by a licensed electrician who follows the electricians' own rules - not the one who installed the wiring incorrectly in the first place. I would have used exactly the phrase that I've underlined in the previous sentence. ONE TEAM - ONE FIGHT!!! Mike I can't comment on your area, but from what I gather from your post, I would have to write up this issue on EVERY home constructed in the state of Maryland, Washington, DC, and Virginia. Because, every home that I have ever inspected (new or old) does not have conduit installed. So, are you saying that every builder, every electrician, and every HVAC tech who has installed cable that is not in conduit from the disconnect to the condensing unit is wrong? I feel bad for John, because he's going to read some of these posts on this thread and think that it's OK to write this up. That is unfortunate. Kevin
  14. Different issue, but I would not write that up as a repair issue either. All three photos are for existing homes, not new construction. Kev
  15. I disagree. A qualified, quality concious tech will mutter, shake his/her head and then get to work cleaning that crap up. The wiring is unprotected, exposed to mechanical damage and presents a clear danger to anyone using just about any tool in the yard or patio area. The insulation on the suction line has been rendered essentially non existent by the water. Well, that's about the most ridiculous statement I heard in a long time, no offense. A little over the top don't you think? Like someone is going to do damage that cable by using "any tool" in close proximity to the it. I don't think so! How does it present "clear danger"? That statement is unnecessarily alarmist. I hardly ever see the cable from the A/C disconnect to the condensing unit in a conduit, except on commercial applications. Of course, I can only speak for my area (MD, DC, VA). Any "qualified" electrician will go out and say "there ain't nothing wrong with this." Here are a few examples.....I guess you'll have to write these up as well....the cables are not in conduit. Again, everyone will have a different view and method of reporting, but this should not have been classified as a repair issue. Kevin Image Insert: 238.5 KB Image Insert: 241.64 KB Image Insert: 239.86 KB
  16. You are missing my point. There is a difference between calling out an item or component as a "repair issue" and an "elective or recommended upgrade." Was the UF cable damaged, broken, or defective in any way? If not, then making a recommendation on providing further protection of the cable would be something that you might want to put in your report as a elective or recommended upgrade. A maintenance item if you will. Calling a qualified technician out to repair something that doesn't need to be "repaired" will only discredit you. You are entitled to inspect how you see fit, but I hope you saved that comment in your report library, because if you are adamant about calling it out as a repair item you will be using it on every inspection that you do. This is a standard installation in our area! With respect to your question above about it being a new installation, the answer is no, not necessarily. Most of the time the existing refrigerant lines and UF cable are used with the new A/C unit. Have a good one Kevin
  17. Was it within sight? Kevin
  18. I would not have called for a "qualified technician" to fix this. Was this the same property that you inspected in Catonsville the other day (built 1953)? This is a pre-existing (old) property and should not be held or inspected to todays code requirements. This is how most of the A/C disconnects are wired in our area. You could have called this out as a maintenance issue or recommended upgrade, but not a repair item calling for a qualified technician to fix it. IMHO Kevin
  19. My quote today from FLIR was 15,750, ouch! I'm going to wait until after the holiday season to upgrade my camera. Kevin
  20. General ITI Scan = 79.00 ITI Electrical Survey = 99.00 ITI Moisture Survey = 99.00 ITI Energy Survey = 129.00 Premium Home Energy Tune-uP w/ ITI Scan = 378.00 These fees are all in addition to my standard home inspection fees. The most popular is the General ITI Scan, because I bring the camera to every inspection and give a short demo on how it works and the benefits of adding the service to the home inspection. Most say "Sure let's add that." It does not take a lot of time to conduct a general scan of the home. I use Home Gauge, and have set up separate sections for each ITI Survey, but include all anomalies gleaned from the General ITI Scan in the body of my standard report. I write up all defects found with the IR camera the same way I would without using. If it's moisture related, then I confirm with a moisture meter. Here are a few example comments: ITI Energy Survey: Maintenance Issue: An excessive amount of air leakage/infiltration was noted at the main entry door. Energy loss is occurring. A thermal imaging camera was used to confirm findings. The thermal images reveal warm air (red spots in image) radiating through the left side and bottom of the door. This is attributed to poor weather stripping. I recommend improving or replacing weather stripping around entire door. Maintenance Issue: A section of the upper wall in the Living room and in the upstairs hallway/bedroom is missing insulation. Energy loss is occurring. A thermal imaging camera was used to confirm findings. The thermal images reveal that heat (white/red areas in image) is radiating through the section of the wall that is not insulated (heat gain/transfer). I recommend installing insulation behind the wall for improved energy efficiency. Hope this helps... Kevin
  21. I think that's the right approach. Sell it as an add-on, have a seperate contract. There's folks out there not charging enough now, and there always will be. Having a camera isn't the only thing one has to accomplish; there has to be an entire package designed around the service. Very good point! Kevin
  22. Sadly, the trend I'm seeing is desperate home inspectors leasing these things and folding them into the normal inspection routine. They advertise the heck out the IR camera and cut their prices to attract lots of business. That doesn't leave me much room to sell the IR service at a premium price. Why should people buy it from me when the "certified" inspector down the street is giving it away? - Jim Katen, Oregon I can't speak for anyone but myself, but I planned on charging an additional premium for my ITI services before purchasing the camera. There maybe some HI's out there that fall into the category you have described, but I think most realize that the market for ITI services is a good one. Charging more for this services is very much feasible in todays market, but it ain't going to stay that way for long. Weather you like it or not, most HI's will have an IR camera in about 7 to 10 years, maybe sooner. You can either get into the game now or be left behind. The "Certified Inspector down the street" comment has nothing to do you charging more for this service. This is business and if you want to be successful, then you have to market aggressively. In less than a year, I am averaging over 1,200.00 a month in additional revenue from ITI. I do more...therefore I charge more! In addition, ITI services are beyond the scope of a standard inspection, and require a separate contract. If you are using the camera on a standard home inspection, it would be wise to ad an addendum to your inspection agreement or have the client sign a separate contract. Just my 2 cents Kevin
  23. I have two of the Streamlight STRION Rechargeable Flashlights. They are by far the best I have used. Both sit right on my belt during the inspection. http://www.lapolicegear.com/ststrefl74.html I also have an ultra stinger, but only use it in crawlspaces. Kevin
  24. I go up on flat or shed style roofs on the old row houses in DC only when there is access from the inside. I also go up on small ranch style homes. I inspect from the ground with Binoculars 99% of the time. Kevin
  25. I offer both. Here are my ITI services: 1. General ITI Scan (add-on to standard HI) 2. ITI Electrical Survey 3. ITI Moisture Survey 4. ITI Energy Survey Kevin
