plummen
    545
Everything posted by plummen
  1. I still come across lead water services quite a bit in north and south Omaha.Im doing an electrical service in a north O that I need to button up tomorrow. It still has a lead service coming in,It even has the old T handle shut off in the basement still which is pretty rare.
  2. [:-thumbu][:-thumbu][:-thumbu][:-thumbu][:-thumbu]
  3. Do you see any blisters in the pipes? C.I normally eats itself from the inside out when people dump draino and acid and other nasty things down drains to clean them out,the blisters are usually a tell tale sign. Ive dug up plenty of C.I ground work over the years that people have dumped that trash down,The top usually looks solid till you open the pipe and see it split/rotted away on the bottom side.
  4. Fancy motorized back water valve?
  5. Is it going into a p trap or an s trap? If its going into a p trap Id probably consider that to be a running trap,which we arent allowed to use around here for maintenance reasons. We arent allowed to use s traps in omaha area,but certain upc areas might be more forgiving.
  6. How old of a house/kitchen are we talking about here?
  7. The lazy installer should have shortened up the whip and strapped it to the house or lineset to support it.[:-yuck]
  8. But in that case, you need to have an equipment grounding conductor in the feeder. Otherwise you have no low-impedance grounding path back to the service panel. The pre-2008 rule was that if there was a continuous metallic path, you needed a 4-wire feeder. That was acceptable pre-2008. After 2008, you always need a 4-wire feeder and ground/neutral separation regardless of metallic paths. [:-thumbu][:-thumbu][:-thumbu][:-thumbu]
  9. Power surge and an open neutral.
  10. Im not talking about the shrader valves(valve cores),Im talking about the actual service valves that are used to pump down the system and hold Freon in the condenser. The service valves get stopped just short of bottoming out against top of the valves when you open them or they will leak,The caps are supposed to be torqued but I crank them down within reason with a decent sized cresent wrench to make sure they seal.
  11. I got called out last week for a 7-8 year old tappan hp that they had some idiot topping off a couple times a year before talking them into putting a new coil in last season. Then a couple weeks after changing the coil it wasn't cooling again,So he tried to tell them it must be a hole in the condenser coil before they told him to hit the bricks. So anyway I went out there last week and couldn't get the hp to fire up,when I threw the gauges on it and found it was bone dry.Big surprise! So I had a good idea of where the problem was before even looking at the service and shrader valves. The high side service valve was covered in oil and some kind of goop inside the cap to try and stop the leak. The clown had the service valve cranked all the way out instead of 1/8" from seated. I showed the home owner what I found and screwed the service valve down just a smidge and cranked the cap down before pumping 300lbs of nitrogen into the system and letting it sit for a couple of hrs without the needle budging and vacuuming the system down and recharging the system. I told them to call me in a couple of weeks when it gets hotter out to recheck the pressure and make sure its running right. Im tired of these clown installers who cant fix anything so they just keep throwing parts like A coils at leaking systems because theyre either just too lazy or too stupid to look for leaks! Ok,rant over.[:-party]
  12. Oh MY EYES![:-taped]
  13. The first one is easy to fix by pulling the top off,Ive never seen one like the second one in 30 plus years of plumbing.[:-bigeyes
  14. Yeah Im going to go with the home inspectors on this one and call it a transfer switch,although its a pretty hacked up looking job to me.
  15. ! trap for each fixture,ditch the san tee laying on its side.
  16. What he said.
  17. I know that if too much heat is applied to stainless steel during welding or fab process carbon is created/added to the material,that will cause rust to form in the material. Im not sure if that's what is causing this problem though. Either way I think csst/trac pipe is really nasty/sloppy looking stuff no matter how its installed.
  18. [:-thumbu][:-thumbu][:-thumbu][:-thumbu]
  19. I remember being busted in the head more than once by a receiver like that as a kid,ah brothers! hahaha
  20. The craziest one I remember seeing was a bathroom fan vented into the side of a brick chimney still being used by a water heater.The world is full of idiots!
  21. I still do a service/mast change out from time to time,Next time I have one with cracked insulation Ill post a picture of what it looks like when I pull it apart.
  22. Im just saying if the insulation got dried out/heated enough to break it down outside theres a pretty good chance its broken down atleast up inside the weatherhead also.
  23. Nobody seems to concerned about the same kind of cracks that are probably present down inside the conduit ,past the weather head.[]
  24. Pex sucks!
  25. Any fitting used on a copper water service buried in the ground should either be silver soldered or a flared fitting.
