electrical is not my strong suit and need some advice. The first pic shows the 100 amp feeder panel with a 100 amp breaker. This 100 amp breaker goes to a second sub-panel (2nd pic) that has a 100 amp breaker that shuts down the panel and is double lugged feeding a 3rd 100 amp panel (3rd pic). Items I think are a problem and need confirmation: I can not find any ground on the 1st main panel, the 2nd panel is grounded and assumed to a cold water line. The neutual from feeder panel is a un-insulated grounding wire? Double lugged neutuals. Can you see any other problems? I am looking for confirmation that this setup is not only dangerous, but the most cost effective way to fix/update the setup. Image Insert: 1529.73 KB
