allspec33351
281 -
Location
Occupation
Realtors best friend
allspec33351's Achievements
Member (3/5)
I recently found two links on my web pages to home inspector's directories. None of which I approved. I am my own web master (not very good) and I publish using Microsoft Front page. I could not get rid of the links even by overwriting my whole web site The site is hosted by my son and he did something to remove them. So besides spam we now have this crap. Please check you web sites for unauthorized links. Mitchell
I respectfully disagree. Flipping a float switch using my professional judgment, a little science, and basic logic. Is exactly what I am hired for. As to time management, my time management is to do the job I was hired. I've spent too many hours too many times at a home inspection but that's my job. Well everything fails it is only a question of time. But I am hire to tell my client is it working today. I am kinda surprised as I have always (mostly) admired your stand against the bucket head realator sucking inspector. When I started in this profession I was a member of the local home inspection association. At meetings we usually had a speaker and one night the very well respected and owner of a large multi home inspection company did a presentation on waters heaters. He explained it all and then said something like now you know what to inspect when you are inspecting a water heater. So the not so shy self asked "so you test the tprv? " "oh no" replied the speaker "it may get stuck and the realator will be upset." I then asked "do you write it up when the tprv goes uphill?" "of course not" replied the speaker Then I asked "do you write it up if the drain line is reduced?" "Listen" he said " you can write up anything you want but if you want to get realators to refer you then don't."
In So Fl almost all the houses have acs. I test every float switch period. That's my job {I think every one turned back on. Some never turned off and that's a problem. } I know this is going to sound harsh but some of you should not be a home inspectors if you are afraid of checking a float switch, a tprv, a garage door opener etc. because of liability. I have NEVER been sued or received a letter because something I tested broke.(15 years) I test what I can to a logical standard. Do you turn a faucet to see if water flows? Well, if you are in the profession long enough; a handle will break off or you can't shut the water off. If you test a GFIC sometimes it will not reset or blow up. I have had acs literally blow up when turned on, dishwashers that flooded the house, showers that took out ceilings, and one refrigerator that was electrified. Come on guys do your job for your client. And if you are scared have the seller sign a release that you will not be liable if you use proper standards and care when testing.
Get a copy of the permits pulled and make sure all are signed off. And make sure all permit were pulled. mlc
http://money.cnn.com/news/newsfeeds/art ... 403995.htm Captain
I will not kill your deal
allspec33351 replied to Darren's topic in Open Discussion Forum (Chit-Chat)
http://www.homegauge.com/report/437706/ mlc -
I have never seen a roof without a drip edge in So Fl mlc
That is not correct. 2006 IRC P2803.6.1 says the discharge may be to the floor, to an indirect waste receptor, or to the outdoors. There must be an air gap in the same room as the water heater. I have only tested one with an air gap and it doesn't work. Nor can I see how one can work. mlc
Based on opening thousands tprv I would say the percentage of "stuck " valves is about 1%-2%. The number that stay open are between 1/2%-1%. Please note that a gentle tap on the top of the tprv usually stops the leak at least until I leave. I would say the decision to not test by inspectors is based on the fear of repercussions of a stuck valve and not based on whether testing of the valve is a legitimate test. mlc
Another interesting read. http://www.nationalboard.org/NationalBo ... sic26.aspx Sometime lifting a lever or pushing a button is the only test we have. I probably will never save a life because of my recommendations but I'm not going to stop. How about if I don't lift the lever I will never know. mlc
I like this http://www.onthehouse.com/wp/19940207 mlc
Maybe I heard about one http://www.dailyitem.com/homepage/local ... 74909.html mlc
Have you ever heard of a water heater that exploded because the TPR valve stuck shut or failed? - Jim Katen, Oregon No ? Have you heard of a fire started or cause by FPE panel ? Have you heard of a fire started or cause by Zinsco panel ? Have you heard of a person being electrocuted by a faulty GFCI ? Have you heard of a fire started or cause by a double tap in a panel ? Have you heard of a confirmed lead poisoning in a residential home ? Have you heard of a confirmed asbestos medical condition in a residential home ? Have you ever heard of a water heater that exploded because the TPR drain line went up hill? Have you ever heard of a water heater that exploded because the TPR drain line was reduced? Have you ever heard of a fire spread quicker because the insulation paper was on top? Have you ever heard of a song in your head but couldn't remember the name of the song??? MLC
For some reason I can't use firefox if I want to upload a file. So I just give you the file locations. http://www.watts.com/pdf/ES-10L-100XL.pdf http://www.watts.com/pdf/F-DE-865.pdf We always talk about following manufactures instructions and I think it is very clear that they want these guys tested for good reasons. I have tested thousands of tprv and could not reset maybe five and in each instance I notified the seller what happened and that they need to call a plumber. I can not recall an instance where I was threatened but a do remember a couple of thank yous. I have found hundred or so the wound not open. Would they open when the temp or pressure called for it to do so, I do not know. I am willing to risk the wrath of a seller to save my client a life or two. won ton soup and white bread mlc
"I can't understand why anyone would do an inspection without one." Well if I don't have an agreement what is a client going to sue you for? A bad inspection; well you should be sued for that. If you have an agreement it is a for the most part a one sided contract so if it is too onerous the court will not like that. In your contract you agree to do this and that and if you don't do it you can be sued. If you have no contract and go above the acceptable area practices you should be fine. All and all I've done many inspections for lawyers and for the most part they believe that agreement are not worth the paper they are written on and your chances of getting sued are less likely if you don't have a preinspection agreement. mlc I am no lawyer and I am not giving legal advice. Please consult a real licensed lawyer for real advice.
