High humidity in new 2600 sq. ft. 2-story home on a crawlspace (6 months old) with A/C running normally (65-70% Rh as indicated on t-stat) also feels very muggy and supposedly T-stat humidity reading was compared to 2 other humidity meters and compared. So weââ¬â¢ll assume the humidity reading is correct. The Heat Pump condenser unit is a Carrier model 25HPA324300, serial 2206E22576. From what I can find out this is a 13 SEER, 2006 model and I think the 24 may indicate 2 ton (puron). The air handler is also a carrier model 58MXB080-F-10116, serial 3405A09316, with propane backup located in the garage (ceiling mounted). These units control 4 zones from one t-stat. The clients had been complaining to the builder about the humidity and the builders HVAC person, who has been to the home a dozen times, downsized the condenser. Makes sense ? Anyway the home is still humid and the HVAC person installs a squirrel cage fan in the crawlspace access door to circulate air in the crawl; so the fan wasnââ¬â¢t really pulling air through the crawl. The home is still humid. While I inspected the home the A/C was running and not much condensate came out of the line. I checked the attic, ran a lot of water, crawled the entire crawlspace and nothing was wrong. The attic was as dry as a bone, nothing leaked, and the crawlspace was clean as a pin, covered completely with plastic. It was damp under the plastic but the insulation wasnââ¬â¢t hanging down and it was all in place. There were no signs of water infiltration around the foundation. So what things could cause the home to be so humid? Is the sizing different for the newer puron systems? Are the newer systems complicated and not well understood by your basic HVAC folks. I told these clients that I was at a loss to explain this and recommended that they request a Carrier regional technical specialist to come on site to analyze and resolve this issue. But Iââ¬â¢m curious and I wanted to get your input. HVAC isnââ¬â¢t my strong area but I thought A/C removed moisture from the air and if the unit was too large and it cooled too quickly it didnââ¬â¢t dehumidify properly. Thatââ¬â¢s probably what the HVAC guy thought. If the 24 in the model number is for 24,000 BTUââ¬â¢s, is that enough to cool a 2600 sq. ft. home? Any thoughts? Thanks in advance for any help, Jim, in Calvert County, MD
