House is a 1977 flip that has a new panel (200-amp). In the panel the legend for the GFCI's point to AFCI circuit breakers. The GFCI outlets have the test buttons/reset on the outlets in both bathrooms. I tripped them and they would not reset. I go to the panel, and the AFCI breaker is tripped. So, I reset the AFCI breaker, go back to the outlet and it still wont reset. I go to another bathroom and find that that GFCI has power. Long story short, I went all over the house and exterior checking to see if any other outlets were tied to the bathroom that I originally tripped and never did get a clear indication of how this circuit was configured. Somehow, not sure how, after several attempts, the GFCI that I originally tripped came back on and I left it alone. My questions is: Can GFCI outlets be connected to AFCI breakers? Also, the AFCI breakers in the panel would not reset unless you pressed the test button(that was already tripped) again to make it release. In other words the test button on the AFCI breaker in the panel would stay "pressed-in" until I manually made it release, then reset the breaker... Any help would be appreciated. Thanks again in advance for your expertise! Click to Enlarge 106.81 KB
