In one of the bedrooms we have a slide dimmer. On the silver backing it reads
120VAC/60HZ
Permanent installed 600W max, 2 GANG 500W or Incand. Fixtures 3 or more GANG 400W
It goes to the top outlet across the room.
I have never heard of a ceiling and outlet on the same switch. Does that mean once the fixture is up the drive will only go to that? Meaning one is in lieu of the other, right? Maybe the ceiling has to be run on a pull chain? Remote? We want to put a permanent fixture for the ceiling.The fixture is a 2 bulb bowl style. How do you make the dimmer work with the fixture not the outlet?
