Here's a blurred finished pic. I was mainly just saying if they just cut the sidewall flashing to fit the corner and then install the pan, it leaves a gap where they meet. But if you leave out the last piece or two of step at the corner, then run the two courses of shingles past the corner, and then install the pan. Now you can cut and install your step flashing to perfectly fit the corner since the gap has been created. On a back pan on a chimney you don't need this method. But I see gaps all the time at dead pocket corners and cricket corners, so I'm trying to get the guys to do it like this. I usually only put ice and water in the valleys and not on walls since I've never seen a properly step flashed wall leak. If I do a dead pocket corner to the gutter, I do put ice and water there though. And yea, never see soldered corners here. Download Attachment: IM000344.JPG 63.74 KB
