1942 Handymans Special
    4
Recent Profile Visitors
1942 Handymans Special's Achievements
  1. Finally got the restring kit in. Completed the restring and it is working great (as good as it ever was anyway). Restringing or rather getting the old elements out was a bit more time consuming than I had anticipated but was not not a difficult task. This is a great lower cost solution. The pictures are post restring.
  2. I went ahead and ordered a Restring Kit 2 elements for ~$30. Only 1 element is broken but I will just replace both. https://www.amazon.com/2-Pack-Napco-Heater-Restring-volt/dp/B0758PCK9Q I will do my best to check back in after I get the parts and install them.
  3. Did this work for you? Looks you had the same original part I am trying to replace. My guess is that since your posts stop you did find that it was a match? I found the same part searching extensively on my own and do not see anything else that is close to a match. Thanks
